Lug nut help...
Old Feb 26, 2010 | 05:25 PM
Lug nut help...
I'm definitely looking into buying a set of new 08 F150 Harley Davidson rims. They come with wheels and center caps only. What type of lug nuts do these wheels use? Maybe one of you HD guys has a pic for me.
I already have some spline lugs for my current 22's but don't know if they're too long or whether or not if they'll work with the center caps.
Thanks in advance.
Old Feb 26, 2010 | 05:32 PM
Veteran: Army
my '01 F-150 used the same lugnuts, so I hope it's the same for the newer trucks...
Old Feb 26, 2010 | 05:39 PM
I know the 08's have exposed lugs.
Old Mar 22, 2010 | 04:04 AM
minner's Avatar
bumping this thread as I am about to buy some 22" 2008 Harley wheels for my F-150 and the lugs are NOT included. Do I need special lugs for this or can they be found at your average wheel/tire shop?
I'm basically asking if the lug seat is different than my factory 18" wheels?
From pictures on the internet of the actual wheels, they look like a 60 degree lug seat.
Old Apr 13, 2010 | 06:11 PM
jtrudel90's Avatar
i have an 06 hd f-150 and chrome caps are starting to split on the oem lug nuts and have spent numerous hours trying to search for this answer ford wants $22 cnd per lug has anyone come upon a fix ....
thanks JUSTIN
Old Jul 8, 2010 | 07:46 PM
dallas23's Avatar
Yes, the wheel lugs you need are unique your splined nuts will not work for the harley wheel application, because Ford uses the wheel lugs to hold on the center caps ( center caps go one over top of the wheel nuts, snap into place), be weary when installing this type of center cap has a habit of falling off while driving. There are two types of nuts that will work the ones for the Harley and the ones for the Limited F150, I recommend the Harley ones there is a subtle difference in the 2. Try to get a VIN off an 08 and give it to Ford to get the correct ones. As far as an aftermarket nut, Good luck, ive found many but almost all say except for Harley Edition. Thurough search u may find something, but from Ford ur looking at about 225-250 CDN for all 24. Check EBAY too. Hope this was helpfull.
