Replacement Shocks
Old Sep 7, 2007 | 09:49 PM
sosdrummer's Avatar
Replacement Shocks
I have a 2000 HD F150. Most autoparts stores don't list the 2000. They start at 2001. Which Bilsteins should I use to replace my stock shocks? The ones for a lightning or the ones for an F150. They are different in the listings.
Old Sep 11, 2007 | 07:54 AM
svt2205's Avatar
The Lightning spec shows should be fine.
If you haven't found these guys, check it out. Probably a better source for HD specific questions.
http://www.nhtoc.com/main.php
Old Sep 15, 2007 | 11:18 AM
kromdom's Avatar
Most HD owner's go with L-spec Bilsteins as svt2205 above stated. I opted to go with 'screw-spec units since I preferred the OEM ride/feel (plus the shocks are correctly rated for the weight of the supercrew).
Also need to factor if you still have a stock rear height (if dropped 2 inches or more, will need shock extenders)
