2006 Harley Davidson F150 Towing Limit
Getting feedback in this area is like growing hair on a rock!!
Anyway, here goes..
Looking at the towing specs of ALL F150s, the 2006 Harley Davidson F150 4x2Supercab, 144.5 wheelbase, 5.4, with 3.73 max towing is 5800 lbs. Whereas the plain 2006 F150 with the same specs, towing max is 9500 lbs.
Are the wheels the factor making the towing less on the Harley Davidson F150from the plain F150s???
Anyway, here goes..
If you really want the HD (and you should
), you could always get a set of regular wheels/tyres for when you want to max out with the towing.
Originally Posted by EnglishAdam
They 20" tyres are the limiting factor.
), you could always get a set of regular wheels/tyres for when you want to max out with the towing.My XLT can cruise at 80 mph with 7x14 trailer with 3 bikes aboard, and 3 humans. The truck is smooth as whistle. At 70 mph with the HD, not only a rougher ride (which I can stand), but vibrations too, and that's without a trailer!
I even thought I might just had a bad HD, with something wrong with a wheel or something causing the bad ride. Was looking to test ride another from another dealer, but when I saw the towing limit cut down, I passed.
Seems like anybody want to tow over 6000 lbs, better get the 250 HD, because max on the F150 HD is 5800 lbs.
