Drag Racing English Style
Old Mar 26, 2006 | 07:03 AM
EnglishAdam's Avatar
Had a good time yesterday at the Santa Pod Raceway in England.
The track was a bit greasy and there was a serious headwind but I did a new PB of 13.92 at 98.9 mph.
Whooohooo
Just to give you some idea of other times being run, a Vauxhall Monaro (same as a GTO) did a 14.2, a Maserati GT did a 14.8 and most of the Subaru's, Evo's and Skylines were in the 14/15's.
One Lightning ran a 12.9 on Nitto Drag radials and another ran a 13.2.
Both have 6 lowers, chips aand cold air etc.
Pretty good times given the conditions.
Funniest bit was sneaking in the ricer lanes and nobody would race me so I had to do a solo pass.
Some Pics
Old Mar 26, 2006 | 06:28 PM
Dbl G's Avatar
Those are some good quality pic's,,looks like a good time.
Old Mar 31, 2006 | 08:06 PM
STOMPTHECHEVY's Avatar
Whooohooo
Some Pics
NICE!! I DIDN"T KNOW THESE BIG trucks could move that quick in the 1/4 mile... So is it the same Supercharger as the lightning??
Nice truck.
WHERE MY MONEYS GONE TOO....
Jet Stage 3 chip//Throttle body spacer//AF1 air intake// Mac performance MAFS//Y PIPE// NO catalatyc Converters//Gibson dual exhaust//CERAMACOATED HEADERS!!/// POSITRACTION UNIT!!! //410 gear ratio//NEW Transmission upgraded W/different gears and more holding power//Centerforce Stage II clutch//Centerforce light weight flywheel// Centerforce throwout//bearing//HURST SHIFTER KIT//My homemade cold air//Shaved heads//Upgraded Injectors/Water pump//REAR drop shackle//FRONT Lowering springs and Nittro drop shocks//I maybe missing something else......
OH YEAH how can i forget!! 75 SHOT OF NITROUS//
20''wheels/ YOKOHOMA TIRES//SHAVED F150 emblem on sides// and back//Air brushed last name//Remote controlled Fog lights//Hoods scoops//TAIL WING//Xtang bed cover//Clear corner lenses//Limo tint// 2 12''SOLOBARICS L7's/ 2 1800 watt punch FOsgate AMPS//Pionner DECK//
Old Mar 31, 2006 | 08:54 PM
jdaniels138's Avatar
where did you find your bug shield?
shoot me a email, jdaniels138@comcast.net.
JD
Old Apr 1, 2006 | 03:56 AM
Stomp,
There's way quicker HD's out there. They are very heavy but if you spend the $$$, you can go as fast as you like.
The engine is the same as the Lightning but with a bigger upper pulley on the blower. In stock form 340hp vs 380 for the L.
The main problem is that the HD probably weighs about 1000lb more than the L due to the bigger cab, doors and heavy *** interior.
JD,
I got the bugshield from a vendor on ebay. Sorry, can't remember the name as it was a year ago.
Try searching on there bud.
Old Apr 1, 2006 | 04:08 AM
Lumadar's Avatar
so does changing the pulley and tune alone literally put it at the same (or better) output as the L?
Old Apr 1, 2006 | 08:05 AM
The engine is identical bar the upper pulley and stock tune.
If you changed the top pulley to a Lightning one and uploaded the Lightning tune, the power would be identical to all intents and purposes.
If you changed just the lower pulley (and tune - very important) your power level would be above a stock L.
If the L made the same mods as you, he would be slightly more powerful due to his smaller upper pulley spinning the blower faster.
As standard, the smaller L upper pulley give it approx. 2lbs more boost than the HD.
The real advantage of the L over the HD is weight. On the dragstrip, every extra 100lb you carry is a 0.1 second deficit.
If the L weighs 1000lb less than an HD, it would be (and is) approx 1 second quicker over the quarter for the same power output.
More Bling = less speed :o
Old Apr 11, 2006 | 09:27 PM
My V6 is doing good along the side of big MOTORS!!
New Quarter Mile Time!! And Very Happy With It!!!
REACTION:-- .6952
60FT:----- 2.1797
330FT:---- 6.5659
1/8:------- 9.8916
1/8:------- 75.05 MPH
1000 ET:---- 12.7256
1000 MPH:---- N/A
1/4 ET:------- 15.1192
1/4 MPH:------ 95.32
THIS WAS DONE WITHOUT NITROUS. So Hell yah!! Im proud of my V6 truck. Shaved off .6 seconds from my best time last time at the track.
14's HERE I COME, Let me get some Nitrous and I will finally break the 15 barrier, And possibly my engine HAHAhaha
https://www.f150online.com/galleries/....cfm?gnum=6980
Jet Stage 3 chip//Throttle body spacer//AF1 air intake// Mac performance MAFS//Y PIPE// NO catalatyc Converters//Gibson dual exhaust//CERAMACOATED HEADERS!!/// POSITRACTION UNIT!!! NOT LIKE U ONE WHEEL SPINNER GUYS //410 gear ratio//NEW Transmission upgraded W/different gears and more holding power//Centerforce Stage II clutch//Centerforce light weight flywheel// Centerforce throwout//bearing//HURST SHIFTER KIT//My homemade cold air//Shaved heads//Upgraded Injectors/Water pump//REAR drop shackle//FRONT Lowering springs and Nittro drop shocks//I maybe missing something else......
