I need more Horsepower
Old May 4, 2005 | 02:56 PM
HarleyKid86's Avatar
I have a Harley Davidson F-150 w/ a K&N Intake, I want to put headers on, can anyone tell me where i should be looking? Also if anyone has more simple ideas for HP gains let me know
Old May 4, 2005 | 05:30 PM
max mitchell's Avatar
Welcome ! Your biggest HP per $$$ will be a chip/tuner. If you prefer headers, these are top-notch:
http://www.secureperformanceorder.co...ProductID=6911
Old May 7, 2005 | 12:52 AM
MiketheAnimal's Avatar
Hey Max, as far as the chip/tuner goes, what are the best to look into? Any other relatively simple and inexpensive ways to get more power? Pulley swap?
Old May 7, 2005 | 10:39 PM
Welcome and hey back. Since yours is the supercharged version, the increased boost from a pulley swap with a matching tune will yield a huge improvement for little effort and money. You can get a tuner with several tunes. You can benefit greatly in stock trim, then load an increased boost tune when you upgrade your pulley and plugs. Depending on boost levels, a K&N drop in filter or a complete air intake kit is also generally recommended. If you look in the supporting vendor area, it lists the vendors experienced in tuning Lightnings/Harleys. The Lightning area of the board also discusses this topic frequently.
Old May 15, 2005 | 03:04 PM
Dbl G's Avatar
You may try checking out the site's in my Sig.
Old Jun 11, 2005 | 05:33 AM
2nd02harley's Avatar
Initial upgrade list.
Here is what I plan on buying right away.
K&N Intake, computer tuner (diablo?), throttle body, quick swap lower pulley at 6#, idler pulleys and spark plugs. After a fairly quick search I found this to be an inexpensive upgrade for some serious power. Is there anything I am missing, anything that doesn't need to be there or am I on the right track.
