Cobra "R" water pump
Old Mar 16, 2003 | 01:08 AM
400HPHD's Avatar
Anybody got one? And what are the differences? Besides being lighter?
Old Mar 19, 2003 | 01:05 AM
speeder's Avatar
Thumbs up Cobra R water pump
They have a closed empeller witch helps them move more coolant, but there not recomended for towing, a stock water pump has an open empeller.
not a good explanation but its the best I can give, I have one on my Lightning and it works great.
Old Mar 22, 2003 | 11:54 AM
LScab's Avatar
My understanding is that since they are more efficient, they can be underdriven and still give the same coolant flow, thereby taking less horsepower.
Bought my pump and pulley, from MAD at www.madenterprise.com/f150.htm great prices, the best service.
Old Mar 25, 2003 | 10:09 AM
ricekicker's Avatar
Registered User
I heard on the "other" HD site that the cobra pump robs HP. A couple people did a dyno test without and with pump and conclusion was it waste a waste of money. Just second-hand info...so you might want to research a bit more.
Old Mar 25, 2003 | 10:51 AM
LScab's Avatar
No argument with that conclusion UNLESS the pump is underdriven, to take advantage of the higher efficiency.
Remember, power consumption on a centrifugal pump varies as the square of the speed. Therefore, if one reduces the speed by 20%, the load requirement decreases by approximately 40%.
Old Apr 6, 2003 | 01:44 PM
HDsupercrewF150's Avatar
English please
Old Apr 6, 2003 | 10:15 PM
LScab's Avatar
OK.
Based on information I have gleaned from other posts on this subject, the Cobra pump puts out a substantially greater coolant flow than a stock pump but in doing so it consumes additional HP.
However, by slowing it down with an underdrive pulley we can apparently reduce the power consumption to less than that required by the stock pump and still maintain better coolant flow.
Most underdrive pulley setups use a smaller drive pulley to achieve the end result. On the Modular Motor this is a NO NO because that would require a smaller diameter Harmonic Damper since our belts run on the Damper OD. Ford probably spent over a million bucks developing the damper for these engines.
SO, the only way we can do it is by going to a larger diameter pulley on the pump.
Old Apr 6, 2003 | 11:04 PM
Good explanation! So if we got a bigger pulley ( the piece that bolts onto the water pump it will give up our horse power back? And what do you mean by modular? TIA
Old Apr 6, 2003 | 11:55 PM
LScab's Avatar
Our SOHC and DOHC 4.6 and 5.4 V8's and the V10 and one of the V6's are called "Modular" by FoMoCo.
This is due to the interchangeability of parts such as rods, pistons, valves, etc., everything except those parts that change when the engine has more cylinders, i.e., block, heads, crank and cams.
