? For those of you that have added gauges
I have added a boost gauge and air/fuel and want to see if I am getting the same readings you are. Vehicle is stock except for a Superchip, Basanni Exhaust and K&N Panel filter. Boost gauge reads 6 to 8 lbs under full acceleration. Air fuel gauge reads in the middle rich range under full acceleration and bounces from bottom lean to high stoich while cruising or idling. Is all normal?
Lance
Lance
Yea the lights bounce all around until you get on it. my gauge usually goes green when the pedal is stomped and then runs high-mid stoich. i was wondering if the gauge was metering the input from the engine sensors or the output from the computer?
