F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Harley-Davidson (https://www.f150online.com/forums/harley-davidson-70/)
-   -   Plasma Booster Ignition Amplifier for GenII's (https://www.f150online.com/forums/harley-davidson/104002-plasma-booster-ignition-amplifier-geniis.html)
HawgGawd Jan 20, 2003 11:32 AM
http://www.nloc.net/forum/showthread...404#post245404
Higher boosted vehicles will benefit from this more than stock vehicles, the average gain in the 1/4 on a 4lb pullied Lightning was .14. On a stock 5.0 mustang with a single coil, a similar unit made 7.9 more hp and 7.9 more ftlbs of Tq, the gains on a coil on plug type of system will be greater. There is a writeup about this unit tested on the 5.0 Mustang in the Jan 02 issue of MM&FF.
Haven't seen any technical discussions of this on the HD forum yet, and that's where I'm interested in hearing folks discuss and test equipment.
I may have to have one if just for the "purty" lights.
Have at it....:D
ken800 Jan 20, 2003 11:36 AM
Waiting on mine...
As soon as I get it installed, i'll do back to backs and let you guys know what it's worth.
Once installed, all you have to do is remove the ground wire and it will not work and not interfere with the stock COP.
I will go to the dyno and let the truck run until the e-fans come on (tells me i am at full op temp) and then do a two-run pull.
I'll let it cool again, then idle again till the fans come on and do another two-run pull with the plasma on.
This way, I can see what top gains I get and what gains I get with a heat soaked engine.
If you guys have any other ideas concerning a good way to dyno back to back, let me know.
*edit* update: it's here. Going to try to work out an install today.
Ken
crockett59 Jan 20, 2003 12:32 PM
Hey Ken,
Over in the L fourm rob02lightning just installed one and has some nice pics
https://www.f150online.com/forums/sh...hreadid=103947
ken800 Jan 20, 2003 12:37 PM
I saw that, thanks... I am a little hesitant to cut into the COP wires... I may try to figure out how to tap in elsewhere as the poster mentioned.
Ken
