bassani xhst question
Old Jan 7, 2003 | 11:31 PM
SSCULLY's Avatar
I found one good picture of the Bassani on an HD ( 01-02 model ) it shows 2 pipes from where the factory Y pipe looked to be at, then went directly to the muffler, a DI/DO I guess, it was not in the picture.
I am looking to see if anyone else has put on a Bassani on an HD, to see if it now includes the X pipe ( seems to be different then the L X Pipe ).
The question I am looking to get answered, is should I get the HD system, or the Cat back system which is a SI/DO like the Gibson ST system that in on there now ( or if the Bassani system is about par with the Gibson, and I am tossing 500+ down the tubes ).
I am real serious now that Tim lowered the price on the system, after kicking it around for ~ 6 months.
If all turns out alright, I should have a Gibson ST dyno sheet, and then a Bassani Dyno sheet as the end results, unless I am pissing cash down the drain.
Any input would be great.
Thanks from a owner of the 2nd cousin of the HD ( SCrew that is )
Old Jan 8, 2003 | 02:39 AM
Ayrton's Avatar
I was told direct from Bassani that the X-pipe is built into the muffler.
Old Jan 8, 2003 | 09:27 AM
HD4mula's Avatar
Mmmm... We may need an X-ray then..
Old Jan 8, 2003 | 10:12 AM
mbrumit's Avatar
When I got my Bassani exhaust (about 5 months ago), I got the one that is for the lightning, and it came with a x-pipe. I installed it on the truck and it works just fine. I have a 02 HD.
Old Jan 8, 2003 | 02:11 PM
richo's Avatar
Mbrumit, what did you have to modify to use the lightning exhaust? Thanks
Old Jan 9, 2003 | 06:28 PM
mbrumit's Avatar
Nothing. It fit very well on the truck. Just had to cut more of the old exhaust pipe off in front of the muffler to install the x-pipe. About 6 to 8 inches. Thats it.
Old Jan 9, 2003 | 08:31 PM
Speedracer29's Avatar
mbrumit, Nice looking truck. Is that some kind of bodie kit you have on there. Looks like the L body molding. I am Fixing to trade my 2001 L or a 2003 HD. I want to use my Bassani and that kit looks good with them.
Old Jan 10, 2003 | 11:28 AM
mbrumit's Avatar
Thanks racer. Just wanted to doing something different.
Old Feb 24, 2003 | 12:09 AM
whitetrash02's Avatar
mbrumit
mbrumit.... i got a question for you. i've got my exhaust exiting at the same place you've got yours. i was told that if you have the exhaust in that location, the acid in the exhaust will discolor the wheels. have you had any problems?? i would think if you took good care of them as in cleaning and polishing them regularly you wouldn't have any problems.
thanks
dan
by the way i love the body kit
Old Feb 25, 2003 | 09:02 PM
4drlitnin's Avatar
I have a complete Bassani exhaust system on my '02 Harley. I went to Bassani in Anaheim, CA in early Dec. and they installed it for me. I decided to use the Lightning system, with headers, high flow cat pipes, two mufflers and tail pipes - the Lightning system. All they had to do was add two 33" extensions between the cats and the x-pipe due to the extra length of the HD, and relocate the tailpipe hanger to exit in front of the wheel. It worked out fine. The single DI/DO muffler they are marketing for the HD in the catback system does have a built-in X-Pipe. I watched them build one of the mufflers since they were using my truck as a test mule so to speak, for fit, etc., and I had originally thought about having them use the single muffler. The catback system they are marketing for the HD is a little easier to install probably since you don't have to add pieces like they did for mine.
Old Mar 4, 2003 | 05:55 PM
mbrumit's Avatar
whitetrash02
I haven't had any problems with the exhaust fumes turning the wheels diffferent colors. I have had that problem when I run super fuel. It turns the wheels blue. Other then that no problems.
Mike
