Rear sliding window problem
Old Dec 23, 2002 | 05:56 PM
4WL HOGG's Avatar
Angry Rear sliding window problem
Has anyone else had a problem the seal in between the sationary an sliding parts of their rear slider? I just noticed the seal was rolling in-between the two pieces of glass when I opened the window.
Old Dec 23, 2002 | 06:27 PM
Harley#356's Avatar
sounds like dealership time
maybe try to take the rear slider portion out yourself to see if the seal just came loose and can be reattached, or if it'll have to be replaced. I'm pretty sure its not that hard to remove the center glass piece. just have to take out a little metal piece at the top and the bottom of the window track to get it out, but not totally sure cuz i've never taken mine out before.
good luck getting it fixed.
Old Dec 23, 2002 | 08:02 PM
Rockpick's Avatar
Moderator &
Not an uncommon problem... take er' to the stealership!
RP
Old Dec 24, 2002 | 07:28 AM
gearhead's Avatar
What I did was "ditch" the slider and put in a solid rear window (my old Lightning - I made sure the Harley was ordered w/o the rear slider).
My reasons were for a cleaner appearance, eliminate a leak probablilty and the biggest is it is the easiest way to break into a truck.
Old Dec 24, 2002 | 08:50 AM
Palumbon's Avatar
I am having the same problem and plan on taking it back to the dealership after christmas.
