SB Chevy build up. Will all this stuff work together?
I originally posted this over at chevy forum but though i would post here to. I know its a chevy but if it goes fast im game. I just need to know if all these parts will work with each other. Thanks.
Hey everyone, new to the boards and looking for some advice. I want to build up that SB chevy I have sitting in my carport. This is my first build up so I need to know if all of this will work with each other. All of these part numbers are from http://www.sdpc2000.com if the decriptions below are not enough info. Thanks for the help everyone.
1. Weiand SBC 8-71 Supercharger-Polished
$2,449.95 $2,449.95
Part Number WEI7185P
Remove Item Qty:
2. 1250 CFM Dominator with Classic Finish
$755.75 $1,511.50
Part Number H0-80532-1
Remove Item Qty:
3. E-Tec 200 SB Chevy Assembled Heads
$1,173.95 $1,173.95
Part Number E6098
Remove Item Qty:
4. Weiand SB Chevy Stealth '55-'86 Intake
$139.95 $139.95
Part Number WEI8016
Remove Item Qty:
5. 350 Blown Lead Foot Rotating Assembly
$2,099.95 $2,099.95
Part Number SD9632K
Remove Item Qty:
Handling & Insurance Costs: $24.75
Grand Total: $7,400.05
$2,449.95 $2,449.95
Remove Item Qty:
$755.75 $1,511.50
Remove Item Qty:
$1,173.95 $1,173.95
Part Number E6098
Remove Item Qty:
$139.95 $139.95
Part Number WEI8016
Remove Item Qty:
$2,099.95 $2,099.95
Part Number SD9632K
Remove Item Qty:
not real sure about super charger applications but, just curious, you didn't mention if the bottom half of the motor had already been built. what pistons, rings, cam, rockers, valves, exhaust etc. sounds like a good start though.
Originally posted by wildchild
...you didn't mention if the bottom half of the motor had already been built...
that is what the Rotating Assembly is. the 5th thing on the list. with everything i mentioned there plus the block i will not have a "complete" engine but i will be pretty damn close.
heres a link to the rotating assembly
http://www.sdpc2000.com/cart.asp?act...id=229&pid=580
sorry i have no clue if it would work or not, but DAMN that would be one sick engine! like someone said, an 8-71 might be a bit overkill for the street. if you plan to use the engine for racing, then why not go with a 383 or even a 427 BB? just curious, good luck!
i was thinking about a 383. i found this kit which may or may not be low enough compression. 9.6:1? What do you guys think?
http://www.sdpc2000.com/cart.asp?act...id=446&pid=569
whoops, i should read a little more carefully.
guess my brain stopped recognizing words after 8-71 blower
im no engine expert so dont take my advice, but i dont think youre gonna take full advantage of that blower with 9.6:1 compression. usually optimum compression with forced induction is 8.5-9.0 . just a thought, good luck with the motor!
yeah thats what i was thinking. thats whay i was leaning towards staying at 350 instead of going to 383. does anyone know of any 383 kits that have an 8.5 compression ratio?
i saw in some magazine a 383 stroker kit for chevy 350's that was all forged internals and had 9.0:1 compression. i cant remember for the life of me where i saw it, but if i see it again ill be sure to post it.
