Need Help
Old Mar 6, 2002 | 01:30 AM
88GT5.0's Avatar
Need Help
HI MY NAME IS IVAN AND I DRIVE A 1988 MUSTANG GT AND I WANTED TO ASK IF ANYBODY KNEW ANYTHING ABOUT MUSTANGS. I WANT TO KNOW HOW TO INCREASE THE HP AND THE TOP SPEED TOO SO IF YOU KNOW ANYTHING ON MUSTANGS LET ME KNOW
THANKS,
IVAN
Old Mar 6, 2002 | 01:56 AM
Donate54's Avatar
hey man,
you should try www.corral.net or www.mustangworld.com , they'll know a lot better than we will. good luck!
Old Mar 6, 2002 | 01:59 AM
J15BIG's Avatar
there are sooooo many things you can do to increase HP. It sounds like you are just starting to get into to cars, am I right? there are many mustang forums where your question may be answered such as Corral.net
http://www.corral.net/forums/
if i had an 88 GT and wanted extra HP the first thing I would do is get the top of the line supercharger and everything to go with it. There are many brands and types too chose from but I would suggest Vortech or Paxton. Then get the upgraded fuel system. Start out with a low boost application such as 6lbs. When your ready for more, beef up the bootom end with new pistons, rods, crank, and a few other things. Then add some boost. Maybe 10lbs. Just keep progressing untill you get it where u want.
any other questions you have just ask. you will probalby get a better response over at corral though.
later
joe
Old Mar 6, 2002 | 05:07 PM
GASGUZZLER007's Avatar
1 Blower= About $2500= Problem Solved! You will have one FAST stang!
Old Mar 6, 2002 | 07:11 PM
DanB 360's Avatar
things a lot of people do that are fairly easy are get new pulleys, a new exhaust system, intake system, maybe a chip, new gears.
most of those are fairly simple and inexpensive (except for new diff.gears).
Old Mar 6, 2002 | 07:49 PM
BULLDOGG01's Avatar
cheap stuff-remove the air silencer box in the fender/k&n filter/advance the timing..you can go as far as 19* btdc on 93 octane...AS LONG AS THER IS NO PING-this will not make it a bracket racer...but depending on your budget every little bit helps
