Door Panel
Lots and lots of little clips around the outer edge of the panel. I tried to take mine off once and discovered that there were even little plastic screws and stuff (this is on a Geo). At that point i said "screw it" before i broke anything else.
On your door panel where the door handle is on the inside, you have what we call a soap dish which is behind the handle, remove that, gently pry and remove the power window/door lock panel switch. Then along the bottom there is screws to remove and the rest is mostly gently snap-tight plastic you need to be gentle with along the bottom or you will create white stress marks if you pry to hard too fast.
I hope this helps and better to have window in the open position or all the way down too. Good Luck and if it is a rattle on a new truck, take it to the dealer, since I work in Kansas City where that truck was built, I would bet it is either a pop rivet head from window regulator or a trim item such as a screw or clip.
ShowYa in Kansas City, gotta go build another Lincoln Blackwood. Have an awesome weekend!
