random beeping
Old Apr 10, 2013 | 11:42 AM
blackmomba's Avatar
gonna take the spacer off today and change the fuel filter and see if i notice anything else while key is on maybe check the air bag connection in the gauge bezel
Old Apr 10, 2013 | 12:30 PM
jbrew's Avatar
Originally Posted by blackmomba
I havent had any problems with the truck but one wiyh the way it ran because of the spark plugs once i change them its been running good the cai is one that says to use oil but i dont put any on...and what do you consider a real muffler..? This morning the wife says she was driving it and it used to do this when it was cold and it didnt get watmed up first thing in yhe morning it spits and sputters and check engine flashes for a lil bit and then iy clears up then its fine.. Maybe time for a fuel filter? Maybe new pump?
A real mufller, = Something you can look into one side and see out the other, I guess. It would probably take a hamster about 45 minutes to make his way thru a Flowmaster.
Yea, just make sure the CAI isn't 3.5" in diameter and you should be alright. If it's 3.5 or above, you better tune it, before....
Yea, the light flashing is misfire monitor counting the number of times it missing, - not running on all 8. If it does this while after cold start, that isn't a good sign. The plugs are fouling most likely, then burns off the residual fuel, dry's out giving the plug more opportunity to fire. You have an injector issue IMO.
That's dangerous because with that, your a candidate for hydro-lock. And that's never good.
Old Apr 10, 2013 | 01:42 PM
Before throwing parts into it, like a pump... look at the fuel pressure off the rails.
04+ the fuel pressure Schrader valve is gone on the rails and needs to be electronically monitored via the obdii ....
Old Apr 10, 2013 | 06:26 PM
blackmomba's Avatar
So im guessing a magnaflow would be better chocie? Ive wented to change it out for awhile too maybe now ill have more reason too lol
Old Apr 10, 2013 | 06:30 PM
blackmomba's Avatar
Your not the first person to tell me that maybe could be a injector but i wish there was a way i can tell for sure that way i can get it taken care of
blackmomba's Avatar
Thanks for all the impuy i apperciate everyones help and i encourage it to keep coming..
Old Apr 10, 2013 | 07:59 PM
jbrew's Avatar
Yea, you have pop the injectors out, push them back up into the rail if they came out, then turn the key to the run position, = KOEO.
Then you monitor/watch the injectors for a few minutes while switched to KOEO.
If the injector drips dribbles or leaks in any way from bottom, -that injector is bad.
Old Apr 10, 2013 | 09:28 PM
jgger's Avatar
Be very careful while messing with the air bag. What I was talking about is the indicator light, if it is burned out you can get a beeping. I think it might be the same with the seat belt light, but I'm not sure.
All you have to do is turn the key to the run position and see if it lights up for a few seconds. If it doesn't then change the bulb in the indicator. If it does light up then the beeping is from something else. Make sure that both, the one in the cluster, and the one to turn off the passenger side work.
If there is an actual air bag issue you should have a code stored. I'm pretty sure that Auto Zone and such can't retrieve those codes though.
Old Apr 11, 2013 | 12:57 AM
blackmomba's Avatar
Doing that with the injectors wont give me air in the system? Just curious.. Thanks jgger!!
Old Apr 11, 2013 | 11:16 AM
jbrew's Avatar
Nah. It'll fire right back up.
Old Apr 11, 2013 | 04:14 PM
blackmomba's Avatar
Thanks jbrew im outside trying a few things now
