Any mechanics in the house that can help?
I am the lucky guy that has been asked to change a water pump and timing belt on a 1998 Plymouth Breeze 2.4L. Never worked on a Plymouth product and don't have any repair manuals for Plymouth. Is it a major pain to do this work on that vehicle or is it relatively easy.
I'd like to know torque specs and timing specs to get the job done. A few pages out of a repair manual would be of tremendous help.
did a Neon not too long ago, major PITA. You ever done major work like this on a similar car?
Electrical connectors have stupid locks that are a pain to take off and usually break
Valve cover has come off, make sure you have new spark plug tower seals
Harmonic balancer (crank pulley) has to come off.
The car probably needs motor mounts so quote those in too, and be ready for them to come off in several pieces.
Timing marks are easy to find and line up (good news)
Thanks for the heads-up. I found out, that I'd need a pacific crank pulley puller, that costs in excess of 350 $, (snap-on) which i don't have. I have a few pullers, but none will work. I am not buying it for somebody else. I'll never use it again. Right off the bat, there is a problem.
I put it to the owner and am waiting for a answer from her. Told her to find somebody that works for cheap. She has financial issues and i was going to do it for free, but not if i have to spend a lot of money out of my pocket.
Nobody i know has that tool to borrow from and no place to rent specialty tools from, near me. Still waiting for a answer from her, as to which way she wants to go with this.
I can get the repair manual download for 12$. I don't mind doing that for her.
I'll wait and see what happens. Should know by the end of the weekend.
Thanks guys.
Thanks guys.
Yes, i been working on vehicles in the past. Not a stranger to engine rebuilding either. Mostly fords and some gm's. Just no chrysler products.
2.2 cavaliers are a lot harder as well as kia sedona (mini van). Cavaliers it has to come out the bottom. Sedona's have about 14 bolts in very strategically annoying places because whom ever engineered those things figured that absolutely everything around the front of the vehicle should be bolted to the rad.
Thanks for the advice.
