2012 fx rims
Old Aug 15, 2012 | 10:03 PM
ppremc's Avatar
2012 fx rims
Will 18in fx rims from a 2012 fit a 2010 f 150 without any problem, it currently has 17 in rims now would there be an issue with the tire sensors, thanks in advance.
Old Aug 15, 2012 | 10:52 PM
Should be no problem with the bolt pattern and back spacing. However, I think there was a change in the style of tire sensors somewhere in there going from the strap-on type to the valve-stem type, which I doubt would be a problem. I'm sure someone will chime-in on that......
Old Aug 15, 2012 | 11:10 PM
kingfish51's Avatar
Sensor change from strap on to valve stem mounted was between 08 and 09. Not sure about any changes with the system between 10 and 12. Same type, valve stem mounted, but not sure about freq etc. I do know that there were changes on how the system was reset, reset tool to using actual changes to air pressure, but not sure of others.
