Which one?
Old Apr 21, 2012 | 11:24 PM
avfrog's Avatar
Originally Posted by fishsniper
I liked the features of the Hobart too. I figure that should be more than enough for anything I'd need, and it'd be a great starter welder. When I'm ready to move onto actual MIG welding, just get a regulator and some gas. One question though...what size wire is good for all around welding, and especially for rocker panels?
.030 should get you started.
Old Apr 21, 2012 | 11:39 PM
aussiekeeper's Avatar
Yup, that is what I use, if you need more penetration just turn the speed up.
Old Apr 21, 2012 | 11:53 PM
fishsniper's Avatar
Cool. I'll probably get another paycheck in and then go for it, so perhaps in a couple weeks, I'll be practicing it all day!
Old Apr 21, 2012 | 11:58 PM
You will be welding in a few passes............
Old Apr 22, 2012 | 01:09 AM
fishsniper's Avatar
I've welded before...with a stick welder...with old rods...and it turned out pretty good
Old Apr 23, 2012 | 02:05 AM
jbrew's Avatar
I use a Handler, for body work. Doing up the rockers use .023 solid wire w/75/25 Argon shielding gas for the best results. Rockers can take a little more heat than body panels, but still take breaks and move around. With that wire/gas combo, you don't create near the heat, -at -least 1-1.5" back to back beads buttoning those up.
Using 30 wire is a little more difficult, - can be done definitely. Without gas, use Lincoln wire only (Fluxcore). DON'T use Harbor Freight wire, unless you have no choice lol. They're little 90 amp Fluxcore welder can be used, as long as you use Lincoln wire with. I use it once in awhile, - but it's not a Hobart, - far from it lol. Duty cycle isn't real important for body work because you have to tag and cool. Anything around 1/8" you'll want it.
Hobarts a great machines IMO, - it's a step down from a Miller machine because some of the parts/accessories used in the Hobart machines/kits aren't as durable or heavy duty. The Hobarts are plenty durable, great machine to work with. I've upgraded the ground clamp, but that's it.
EDIT: BTW- You can purchase new tanks online, Full 75/25 for around $120. That's for a small one tho. Tractor Supply usually won't carry supply the tanks/ -insurance reasons I've been told. A Welding supply outlet local should be the cheapest route.
Always purchase as much welder as you can afford. You get what you pay with the name brands IMO. Also, if your thinking of used. Look at an older Miller, - damn things are bullet proof and will perform.
Old Jun 4, 2012 | 11:13 PM
fishsniper's Avatar
So, after some more searching, it's still between the Hobart and this one I found at Lowes:
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Would y'all choose Lincoln over Hobart or vice versa?
Old Jun 5, 2012 | 01:35 AM
jbrew's Avatar
Either, both are about the same. Get as much welder as you can afford.
You need more or better. Most of those old millers are about bullet proof, - so used is a good investment there. The best, can't get much better than a Miller.
Old Jun 5, 2012 | 11:05 AM
DewserB's Avatar
TRUCK OF THE YEAR 2013
Sorry. Carry on.
Old Jun 5, 2012 | 11:22 AM
SETCHAN's Avatar
Build Tracking Moderator
Please buy a American welder.
Miller makes light duty machines, but you'll eventually outgrow any small welder.
Had a Millermatic 180 and within 4 month bought the Millermatic 252.
All's real good now!
