Pipe threader (which one ?)
Old Apr 2, 2012 | 10:10 PM
jbrew's Avatar
Hey fellas, - I need a pipe threader,- 1/4" - 1.5" dies. Won't be using allot, but want one that's that's going to work when needed. I've seen quite a few of these kits out there very cheap, -
http://www.ebay.com/itm/330679804600...84.m1438.l2649
That's just it, very cheap can be scary.
I'm thinking I would be further ahead finding an older used RIGID (ratchet set), -would like an old 700 series threader, if I could find one reasonably priced (doubtful).
Going after this one currently, not sure I'll win, but I think it's all I need besides a cutter.
http://www.ebay.com/itm/Ridgid-pipe-...item3cc439fecd
What do you think, - new cheap any good ? Or stick with a used RIGID ?
Thanks!
Old Apr 2, 2012 | 10:40 PM
worm5932's Avatar
Rigid. If you go cheap the dies will not last and you won't be able to find the right ones. A rigid ratcheting will last forever.
Old Apr 3, 2012 | 12:01 AM
SETCHAN's Avatar
Build Tracking Moderator
Ridgid is the way to go
Old Apr 3, 2012 | 12:02 AM
jbrew's Avatar
Thanks, I thought that might be the better choice.
Looks like I won that auction , - didn't expect to at that price.
Good deal!
Old Apr 3, 2012 | 07:29 AM
jbrew's Avatar
Originally Posted by SETCHAN
Ridgid
At least someone spelled that right
Old Apr 3, 2012 | 07:41 AM
SSCULLY's Avatar
Wow, got it for cheap.
I was going to suggest trolling the local CL listing, in the Chicago area I see all sorts of shops for sale from plumbing to solid surface counter tops.
That unit should serve you well, and if something happens to one of the dies, you can replace them each enough.
Old Apr 3, 2012 | 07:56 AM
SETCHAN's Avatar
Congrats. Let us know how it works. The dies look good from here....good deal!
Old Apr 3, 2012 | 08:05 AM
jbrew's Avatar
Yea, the cheapest new set that included one more alloy die (3/8) was about $270. The 12R set. Average price for new w/shipping would of been close to three hundy.
I like that when no one bids against yuh.
Old Apr 3, 2012 | 08:13 AM
jbrew's Avatar
Yea , everything looked good. From what I recall, you can get a rough idea how used they are from looking at the paint on the die heads. The paint usually doesn't last that long with continuous use. - Just a rough idea.
Now I need a cutter (Ridgid). Found only two so far, -cheap, but those auctions have just started without a "buy now" price. I haven't check Amazon yet.
Old Apr 3, 2012 | 08:23 AM
SETCHAN's Avatar
You'll also need one of these, unless you already have it.
http://www.zorotools.com/g/Pipe%20Th...ises/00057980/
Wouldn't want to buy it new......check out the price.
Old Apr 3, 2012 | 08:31 AM
jbrew's Avatar
Yea, I have a couple of those, - both shop vises have an integrated pipe vise. I think I'm just about set. Except for oil, might get a better reamer. That's not a problem, just up the street.
Old Apr 3, 2012 | 08:33 AM
jbrew's Avatar
I know, stuffs crazy expensive. - Good stuff tho. Hell, I'll keep going the used route, - think I'm on a roll.
Old Apr 3, 2012 | 09:10 AM
worm5932's Avatar
Hahaha. I look at one every day and I didn't.
Old Apr 3, 2012 | 10:05 AM
SSCULLY's Avatar
You did really good, just looked and the best I can find with a quick look ( ridgid only ) was 185.00 for a set with 1/4, 3/8, 1/2, 3/4, 1, 1-1/4 and 4 steel ridgid pipe wrenches ( looks like a 12", 2 16"? and a 24" )
there were a few bids on that auction, but not what I would expect for such a low price.
Old Apr 3, 2012 | 12:17 PM
jbrew's Avatar
That's why I didn't edit and correct it. You did the same thing
