Hard Hot Starter
Hard Hot Starter
1994 F-150 XLT
6 CYL
No charging system faults,truck starts fine on cold start
But does not want to start when hot
Carry's 14.5 volts while at idle
All connections are free of oxidation
Also have tones:series of 5 tones 5x
Thanks for input and
Keep on Truckin!
6 CYL
Keep on Truckin!
Timing could be too far advanced.
Starter could be going bad, and just not working right when it gets heat soaked.
Is this an EFI or carb motor? If carb, could be fuel boiling.
Is the fuel good?
Is the cooling system working properly? IOTW, just how hot is the motor getting? Running close to overheating could be a factor...
Are you 100% sure the plug wires are hooked up in the right order?
Is the fuel good?
Yeah, is it slow cranking, or does it crank normal speed and just not want to fire?
If slow crank, probably the starter.
If it cranks normal speed, it could be fuel boiling in the rail, or low fuel pressure/weak fuel pump.
