2012 explorer
Old Jan 27, 2012 | 11:14 PM
dirk upson's Avatar
2012 explorer
are the 2012 ford explorers all wheel drive or four wheel drive? i know it says 4wd, but doesn't have a neutral like my truck. it does have different settings for different conditions. i was wondering if the normal setting is still all wheel drive.
Old Jan 28, 2012 | 12:13 AM
ian51279's Avatar
If it has a selectable low range, it's 4WD. Usually your AWD systems are only a single speed t-case which is high range.
I had a '97 Explorer 4x4, it didn't have a neutral either. The switch had 2WD-4HI-4LO.
I'm not sure exactly how the Advance Trac systems works on the newer models, I've not been in one.
Old Jan 28, 2012 | 12:08 PM
It's an "intelligent 4wd" system which is essentially AWD. "Normal" is FWD but it will kick in the rear wheels if needed.
