True RMS
I've got an old space invaders game I'm working on when I' in the mood (lazy).
It has a huge transformer in it, with many voltage legs coming off of it. I think I've isolated the problem to one of the voltage legs. I'm trying to figure out the amperage transformer I need to replace that leg with. I'm not expert on electronics, (plus this stuff is antique), do you have any suggestions?
How did you narrow it down to the transformer ?
By testing the individual legs with a VOHM.
The machine was built in 1979 I think.
It's an arcade console. It says 25Cents on the coin slot, but I rember them taking 50C.
I've seen them on Ebay (in better condition than mine) in the $800 price range. I remember when they were new they sold for about $1500.
Right, and as someone else alluded, if you're measuring a type of wave that has less than the 50% duty cycle of a "pure" square wave, as in a variable-speed motor controller that is varying the pulse width between 0% and 50%, only a true-RMS measurement circuit is going to give you accurate readings of the delivered power. A "garden-variety" meter will read either too high or too low, depending on the type of measurement circuit the meter was built with.
Fluke has just published a paper Why true-rms discussing how non-linear loads need a true-rms current clamp for accurate readings. http://www.newark.com/pdfs/techartic.../whyTueRMS.pdf It also includes application notes. Also, here's the main Newark Fluke page www.newark.com/fluke.
