How do you secure a screw in a Socket
While removing/replacing the instrument cluster I had the darnest time getting the screws back in place. I had to use a socket with an extension but since my "angle of attack" was down hill the screws kept falling out of the socket. I ended up using tape to hold the screw in the socket until I got the screw where it needed to go. I was wondering what technique others use to secure the screw/bolts in a socket?
DOug
DOug
Magnetic nut driver, magnetic screw driver or just take your screw driver and dip the tip in grease and the screw with normally stick if it's small.
small layer of plastic, like a sandwhich bag will hold the bolt snugly. Also make sure you're using the correct size socket as well.
