Anyone with welding knowledge?
Old Jan 2, 2011 | 01:43 PM
jbrew's Avatar
Originally Posted by Klitch
I thought the idea, if using a smaller welder, to build your weld in layers and it will be just as strong as using a larger welder and less passes.
Right, it sucks/time consuming, but it can be done with more than enough penetration. Believe me, I've tested it lol. - Good practice for a beginner.
Old Jan 2, 2011 | 01:56 PM
zacky's Avatar
Buy a Hot Glue gun will hold your trailer together just as well just needs more pass's
no wonder people are killed and others are sued penniless
Old Jan 2, 2011 | 02:52 PM
Klitch's Avatar
I cant count how many "certified" welders have told me similar stories. Far as I'm concerned ya'll are liars in a pissin match.
Old Jan 2, 2011 | 03:01 PM
Klitch's Avatar
At any rate, it dont matter to me, I got me a new welder for cheap that hasnt been used in 10-15 years. Company changed hands and got rid of the forklift maintenance, decided to lease.
Old Jan 2, 2011 | 03:44 PM
jbrew's Avatar
Well quit given'em idea's
Old Jan 2, 2011 | 07:42 PM
mudkickin4x4's Avatar
Ive found a lincoln 225 arc welder (The big red ones), should i just go ahead and get it?
Old Jan 2, 2011 | 07:45 PM
SSCULLY's Avatar
I got a 120 A Astro gas/no gas welder some time ago, the key is to take your time.
The other thing I found, you can get a 250 A welder, if you have a crap circuit to the outlet for it, the transformer will keep cycling.
The 130 I got is a 120 V welder input voltage, and 28 A draw, I used a 30 A breaker and installed 8 AWG wire to the outlet in the garage ( shortest route to get there ). 10 AWG would work with 35 A, for general items.
Don't make the transformer work as hard with the input voltage and it will be good to go.
I did the SS xhst on my 2001 with it, I am not the best with SS welding, as I have not done it a lot.
The small box welders will work just fine, as long as you are welding correctly, not trying to use wire as glue.
Also, keep in mind the design of the item you are building, make sure to have supports in the corners where they are stressed. This is all building 101 items.
Old Jan 2, 2011 | 07:48 PM
or a campbell stick welder new for 100?
Sorry guys, i know alittle about welding. I just dont know what machine to get. i cant spend alot
Old Jan 2, 2011 | 07:58 PM
avfrog's Avatar
I am spoiled. I weld 40 hours a week with a Miller Syncrowave® 250.
Old Jan 2, 2011 | 08:01 PM
Tumba's Avatar
I've got a cracker box like that also. My Dad gave it to me, and it's probably 25 years old, and still works like a champ. I'll go to it before I will the flux core wire welder.
Also as SCULLY said, keep the wiring the shortest distance possible
Old Jan 2, 2011 | 08:12 PM
99rckstrexpy's Avatar
who do you weld for avfrog? ive been welding for about 3 and a half years now and i just finished school with my welding diploma, but i have about 8 more weeks of a nuclear pipe acadamy to finish through progress energy and im trying to find a good company to get on with.
Old Jan 2, 2011 | 09:52 PM
Zaairman's Avatar
Those little Harbor Freight welders aren't good for much more than some sheet metal. Unless if you already have the steel, it'll probably be cheaper to buy a small used trailer.
Old Jan 2, 2011 | 10:07 PM
06F150STX's Avatar
Originally Posted by zapster
FYI..
Basic rule of thumb is 1 amp per .001 material..
Example 1/8"=.125 so 125 amps and up..
1/4"=.250 so 250 amps and up..
Com'on over and sign up..
http://weldfabzone.com/forum/index.php
Ask a few others there that don't know anything about what you claim you did and see what happens next..
I have been welding for 35 years..
Government Cert in Mig Tig and Stick..
Nope I don't know anything
Just stay away from me with your trailer..
...zap!
x2!!! I'm a certified mig and stick where I work. I myself own a Hobart Ironman 210 mig at my house. We use Miller 652's where I work.
Old Jan 2, 2011 | 10:19 PM
zapster's Avatar
Cool!..
I have a Miller 330A/BP Tig machine that goes to 460 amps..
Watercooled WP20 torch and all the goodies..
Positioner..
Rollers for shafts..
Lincoln AC DC stick machine that will go 400 amps..
But yet I know nothing..
Go to the site and join..
I am in Admin...
...zap!
Old Jan 2, 2011 | 10:25 PM
Klitch's Avatar
You're spoiled.
