Jeep Project 27in. lift should i get it?
hey guys well after my idea of making my fourwheeler float on water pretty much failed before it got started i found this jeep cherokee on craigslist for $800 or a set of good tires. im wanting to get a set of rockwells eventually and swap them out under it since he did all this stuff to it while it still has stock axles
. i've talked to him about it and he said the engine runs fine and has an extended rear drive shaft. NOTE: this jeep would only be for a toy to play in some mud and stuff so im not really concerned about the work craftsmanship thats already been done to it. my cousin has a welder and we could pretty much make everything needed for it work. plus it's only like 10min.s away from me so ill go and check it out first. thoughts?
http://atlanta.craigslist.org/atl/cto/1611576233.html
Last edited by dilloncawthon; Feb 26, 2010 at 12:37 PM. Reason: forgot the link lol
hahahaha i don't think the pontoons would ever hit the water. i do have like 4 cans of DSG paint so if i got it i may paint it the same color as my truck
. the only problem im having is finding some cheap rockwells.
well its meant to be just a toy for offroading, and its a good start to building it up big from what i can tell.
Toys that break all the time are not much fun.
That's the kind of rig that will break something just going down your driveway, so I would not count on it to do much offroading.
IMO, a tow strap, a winch and a buddy with a reliable vehicle will be necessary if you try to offroad that thing.
My forewarning is, your getting yourself into a mess with something like that unless you know what your doing. First of all cherokees are uni-body meaning its weak as crap. You will twist so easily it's not funny. If you want rockwells I have a feeling your gonna want another engine, the inline 6 is a great engine but not made to move 1 ton axles. Also with tons your gonna need to setup a custom suspension which would probably mean 4 link front and rear, unless you want to pay a shop to do it.
It's up to you, but I bet you have a lot of money and time tied up in it before its all said an done if your carry out your plans. I just sold a grand cherokee that I was going to fix up for rock crawling. Decided I would waist way to much money to do it, and I wasn't even going as big as you were. I will just stick to my yj for now. 39s and a belly height of only 18" does me pretty good.
I'm not sure you will get any off-roading done in that other than maybe a gravel road at <15 speeds. You pull up on any rock bigger than 2 ft tall and your going to roll it.
