Should the F-150 go unibody?
Does anyone else see the humor in a thread, designed to stir the poop on a pick-up site, being started
under a screen name taken from the guy who stabbed himself 6 times... and still couldn't get it right?
Pros of Unibody:
Better handling
Lighter
Faster
I personally think they should make the F150 unibody, like the Honda Ridgeline. The Ridgeline is a perfect truck for any purposes, while the F150 is clinging onto a past that has gone away long ago.
What are your thoughts?
Better handling
Lighter
Faster
But that is not to say there are not towing advantages to unibody vehicles if they have an appropriate form factor. For example, the VW Touareg is well known to be a fantastic tow vehicle right up to it's rated 7700 lbs. even though many believed it's wheelbase was too short to be stable towing such loads at speed. However, it has since proven itself to be a sure footed tow vehicle even at higher speeds with larger trailers. That's because it is very rigid and doesn't feed energy into trailer sway oscillations. The very rigid unibody chassis can transfer the trailer sway energy directly into the suspension dampers to stop oscillations before they become problematic. And that is why it often highly praised by those who have experience towing with more traditional tow vehicles that have body on frame designs.
But real pick-up trucks should continue to use body on frame designs because of the open bed that does not lend itself to a rigid unibody design.
a ridgeline is not a truck...look under the hood of a Ridgeline not only is it a unibody, ITS GOT A TRANSVERSE MOUNTED ENGINE AND A TRANSAXLE! guess what your trucks primary drive is the front wheels!
My F150 pukes up ridgelines all morning as it goes to work after hanging in the bars all nite drinking straight shots.
And it still gets the job done.
Can that ridgeline even handle straight gas? Or does it need to be milked down?!
you mean '61-'63 with '63 being the split year, like '65 and the twin I-beam suspension
they still had a ladder frame...
