4.2L engine misfires!
After posting a thread earlier regarding the Camshaft Position Sensor problem and installing a new one with a connector that fits, I now have a major issue as the motor is running. I have misfire from idle all the way thru driving at higher speeds, like something else got fried besides the Camshaft Sensor.
How can I diagnose the problem or does anyone know what else may have gone wrong?
Do note: The replacement connector that I spliced (used), seemed to have a smaller ground wire than the wire coming from the PCM wires. Would this cause enough Amp and Volt difference to make the misfires?
