E-150 help!!!
Old Dec 21, 2009 | 11:10 PM
neorulzu2's Avatar
E-150 help!!!
I have a 1993 F-150 flareside and parked it when I bought a 1999, E-150 Econoline van. Is there any help here for a problem with the van? If so, please reply with the following problem.
I had to replace the thermostat. To get to the cover bolts, I had to unplug the Camshaft sensor. When I plugged the connector back into the sensor, the rubber band inside the female connector was loose and would not go back onto the male sensor end. I had to discard the rubber band for the connector to snap in place onto the male sensor end. I then noticed the 4 (ground) wires that were coming out of the back of the connector had all been touching together and not seperated.
It was like this had been redone by someone that had just jammed the 4 wires into the plastic connector piece. I put all the parts back together and tried to start the motor, but there was nothing but engine turn over. After reading up in the repair manual about the camshaft sensor, the only thing that I can think of that is not working, is the correct connector sequence into the camshafter sensor receptacle.
Anybody ever have this problem. I mean, how hard is it to replace a thermostat on any FORD?
Old Dec 21, 2009 | 11:17 PM
Paralyzer's Avatar
Your best bet would be to go to the dealer, get a replacement connector and the pin out diagram. Splice in the new the connector and re-test. If it was running before it IS most likely your problem.
Old Dec 21, 2009 | 11:19 PM
f150fella08's Avatar
thermostats arent that bad..on my 4.6 it was easy..took the intake off and BAM right there..the 4.2 is a little tougher..which motor are you talking about
i assume the 5.4 is that same as the 4.6
Old Dec 21, 2009 | 11:21 PM
neorulzu2's Avatar
It is the 4.2L, with over 224,000 on it. Just to mention, I sprayed some electrical degreaser all over the sensor and the connectors. Would this cause a problem other than the connectors?
Old Dec 21, 2009 | 11:22 PM
Paralyzer's Avatar
he has a 93 so its most likely a 5.0 or a 5.8. They are not near as easy to work on
Old Dec 21, 2009 | 11:23 PM
the 4.2 is a little harder to do than the 4.6/5.4
paralyzer he is changing the thermostat on the E150 which is a 1999
Old Dec 21, 2009 | 11:24 PM
neorulzu2's Avatar
The new connector seems to be the quick fix. Thanks Paralyzer! The sensor replacement is a tough one to attempt, although it is only 2 bolts to unsrew! Getting to the bolts is the hard part!!
Old Dec 21, 2009 | 11:25 PM
neorulzu2's Avatar
BTW..... my F-150 is still up for sale! I spent well over $10k in it and can only get an offer of $1,500 for it.
Old Dec 21, 2009 | 11:27 PM
neorulzu2's Avatar
I bought the van for $2k and found out it eats just as much gas as the F-150 does (11MPG)!!!!!
Old Dec 21, 2009 | 11:29 PM
neorulzu2's Avatar
Got any idea how much the connector part will cost me?
Old Dec 22, 2009 | 10:17 AM
neorulzu2's Avatar
I took the connector off and will replace it. However, since the three wires were all touching each other, have I damaged the sensor when I tried to fire the engine?
Old Dec 22, 2009 | 11:56 AM
ranger81's Avatar
What's your 0-60 time?..........I think that's measured in hours......
Old Dec 23, 2009 | 04:21 PM
neorulzu2's Avatar
FUNNY! BTW.... I changed the connector and installed a new camshaft position sensor, and the van still won't start. The old sensor looked like it got melted a bit. Anyone got a clue where I go next with the diagnosis?
