Tape measure alignment?
Old Aug 24, 2009 | 01:27 AM
mark661's Avatar
Anyone know if you can use a tape measure and level to adjust camber/caster after a leveling kit installation? I used to do tape measure alignments on Mustangs after lowering for years without tire wear.
Old Aug 24, 2009 | 04:27 AM
code58's Avatar
Originally Posted by mark661
Anyone know if you can use a tape measure to adjust camber/caster after a leveling kit installation? I used to do tape measure alignments on Mustangs after lowering for years without tire wear.
How do you do a caster alignment with a tape measure? What's that called, a "Hillbilly alignment"?
Old Aug 24, 2009 | 06:46 AM
Tumba's Avatar
You can get the tow in with a rigid measuring stick, but how would you get the chamber and caster right?
Old Aug 24, 2009 | 09:39 PM
mark661's Avatar
Camber/caster with the use of a straight edge level. I thought it was enough information to explain my question.
And the term is SHADETREE alignment on the west coast! "Hillbilly" where you live code58.
Old Aug 24, 2009 | 09:48 PM
azmidget91's Avatar
yes you can although it will be a lot more accurate at a shop done with lasers
i suggest one of these though
http://www.pitstopusa.com/detail.aspx?ID=11045
Old Aug 25, 2009 | 04:27 AM
code58's Avatar
Since we both live in So. Cal. guess it's either "shade tree" or "hillbilly" for both of us. I've done a lot of alignments and I still don't understand how you do caster with a straight edge. Guess it's because I never did it that way.
