Need advice on truck im poss buying
New guy here wanting to get some good advice & some ford knowledge. Im in the process of buying a 2006 f150 xlt extended cab 4x4 5.4l 6.5ft bed pickup with a manufacturing date on door of 3/06. I used to be a mechanic but not close to being ase certified or a ford expert. This truck has 36,000 miles & has basically every option except leather & is in excellent shape. The only thing i can see that it needs is front pads & there is a small leak where the driveshaft connects to the rear diff. I did a carfax report & truck is clean. The report also shows the services performed by the dealer before it was sold to my friend & mentioned that the catalytic converter was replaced at 22,000 & one of the fuel injectors along with spark plugs soon after. Has anyone heard of this happening & were they possibly just bum parts. Through the research ive done so far on this model, it seems to be an excellent truck & there are no known recalls. Im purchasing it for $14,000 & basically wanted to know if this is a steel & if theres anything i should know about this model. Any feedback would be much appreciated.
The biggest problem is going to be when you decide to change the spark plugs. It's a major issue, the 2 piece plugs like to break and stick in the heads.
If it's an early 06, I can see where there may be fuel injector issues - the 05's had a problem with leaky injectors. There is an extended warranty on those if your build date is covered.
I bought mine with 48k in February and now have 53k and havent had any issues with the truck other than the cheap tires the dealer put on but I replaced them and the vibration went away.
With only 36k I dont think you have much to worry about.
since the truck date on the door is 3/06 im worried that the bad injector problems from the 05,s is passed on to this truck. anybody know an approximate cost to replace all the injectors for piece of mind & also if covered under the extended injector warranty, would they replace all or just each one as they fail.
