engine stalling need help
Old May 23, 2009 | 08:49 PM
Terminateur's Avatar
Hi,I have a Ford F-150 1997 motor 4.2 4X4.I had no time to change my (wires,plug,and my coil pack)so my truck was at a garage they gave me my truck back and after 30 minutes my truck was not starting and when he did start I could not drive 1/2 miles he stall at every stop.
If I put it on a neutral at the stop and hold the gaz pedal he will go if I pomp the gaz to keep going.
at the idle is ok but as soon I engage at drive or reverse it stall.
If somebody can help me please,
Old May 23, 2009 | 09:14 PM
Tumba's Avatar
Have you ever changed the fuel filter?
YOu should post this in the v6 engine forum, you will get more help there.
Old May 23, 2009 | 09:21 PM
How a truck run well and they change those part and came out of the garage with this problem
Old May 23, 2009 | 10:16 PM
if it was the fuel filter the truck will have problem on the road but my problem come only when I am on engage drive or reverse at the stop .as soon I can go after the stop I have no problem the truck is ruuning well but as sonn I take out my foot from the gaz pedal at the stop or slow dow the rpm is going dow and dow and stall,I restart the motor with no problem .
Old May 23, 2009 | 10:36 PM
Tumba's Avatar
Click this link and read it. This is probably what you problem is.
The garage may not have plugged the wire back correctly, or it is dirty.
https://www.f150online.com/forums/v8...e-problem.html
