Can some one help please
Old May 13, 2009 | 11:15 AM
XL1's Avatar
XL1
hello? i recently traded my nissan altima for a 1991 ford f 150 4x4 5.8liter. I have a month with the truck and i still havent been able to drive it
the truck would not stay running i clean out both gas tanks change the the ignition module put in new spark splugs new wires new cap n rotor new battery including a new starter also a buddy of mine adjusted the timing cause first it would start but will not stay runningi guess by cleaning out gas tanks and changing spark plugs and wires cap and rotor finaly it will stay running was still having trouble with with starter but replaced that yesterday now the truck just kicks over but will not start can some one help me out i just dont know what else to do.
Old May 13, 2009 | 01:03 PM
Post in the pre-1997 forum:
https://www.f150online.com/forums/pre-1997-models-51/
Also, people will be a lot more inclined to help you if you could take the time to form sentences and use punctuation. What you just posted is very difficult to read and follow because you are just rambling.
Old May 13, 2009 | 01:28 PM
pgh_medic's Avatar
Fuel filter?
Fuel pump?
Are you getting fuel pressure?
Is this injected or carburetor?
Injectors or carb could be clogged. Sounds like more of a fuel issue than anything.
Old May 13, 2009 | 05:48 PM
Rambo's Avatar
Take it to your local Ford dealer for a diagnosis.
Old May 13, 2009 | 08:31 PM
If it's a stick shift you had to depress the clutch and hold the brake in order to get them to start. Just a guess. Also check out the coil.
