Belt help please
Old Apr 11, 2009 | 03:20 PM
2000f150v6's Avatar
Belt help please
today the belt on my v6 f150 snapped. I got the new belt on and everything on,no problem but it will not get tight for me. the tensionor pulley is spring loaded and i can't really do much manually with it except turn it then it goes right back in place. any help is much appreciated, i have about an hour before i have to be at work.
Old Apr 11, 2009 | 03:22 PM
Is the tensioner tight? Or did the tensioner break?
Are you sure you are following the correct belt routing?
Old Apr 11, 2009 | 03:28 PM
2000f150v6's Avatar
the belts through right the tensionor is still moving and everything but its not putting any tension on the belt.
i took the belt off of my other same exact f150. it didint work, and when i tried to put it back on the truck it came off of im having the same problem.
Old Apr 12, 2009 | 03:09 PM
chiefFX4's Avatar
you need to check the routing of the belt.
