HDMI splitter
HDMI splitter
Can I split my HDMI cable and display HD cable DVR on two TVs? I'm looking at HDMI splitters and switches. On many units I see this caution:
"Due to the current state of the technology, results using HDMI and/or DVI splitters can be mixed. Especially passive splitters which reply on the individual devices ability to negotiate a 3 way handshake. The problem is not all devices are programmed to deal with this properly and will sometimes default to an HDCP error state. To put it simply, some devices will consider a split of the signal to be a copyright violation, so it may decide that only one display should show at a time or may block the content entirely. This type of situation is considered to be a device compatibility issue and can not be fixed short of a firmware update by the individual device manufacturers"
Is anyone running two TVs off of one cable box? Yes, I do want to see the same show on both TVs.
no but i have an HDMI - HDMI,DVI splitter so i can watch the tv on the big screen or moniter, and play 360 on either also
works well...have to have seperate audio
edit for link
click for splitter
what price range are you in?
edit for link
click for splitter
edit for link
click for splitter
edit for link
click for splitter
x2 - If you try this, let us know how much you can tell the difference. I have experiment with both types of cables with my customers several times, and they can never tell me which cable was the HDMI.
I can't tell the difference between HDMI and component anyhow. Then I'll still have an HDMI port open for BlueRay and something else.
"The included IR remote allows you to switch the input from the comfort of your viewing position."
which is something considering how cheap everything
