thinking of buying 1979 F150 with 460 - Opinions needed
Old Mar 28, 2009 | 05:55 PM
jimc2004's Avatar
Hey guys, I could use some input here. I would like to get a dedicated offroad truck and stop beating on my 2004. I always wanted a late 70's Ford with a 460 to have and build up. I came across this one, let me know what you think about price and such. I am kind of new to older trucks, so some help would be appreciated. Here are the links to the two different adds.
It looks like good starter. OK 35" tires that should do great in the sand dunes ( A lack of tread can be GREAT for sand, less digging ). 9 inch with Detroit Locker in rear, Dana 44 with truetrac in front. 4.11 Gears
The 460 seems to be pretty built. I will admit I don't know much about this kind of stuff though. I just know I think a 460 is really cool (no replacement for displacement). I guess buying this would be a good way to learn about them.
1) http://www.greatlakes4x4.com/showthread.php?t=122544
2) http://grandrapids.craigslist.org/cto/1076919926.html
Thanks - I appreciate any input
Old Mar 28, 2009 | 06:22 PM
Matts ford's Avatar
i love those old 70's pickups but for 3000 dollars i dont know about that one. the most i would personally give for it is about 2000. everything looks to be good. frame looks pretty good from what i could see. the body looked pretty good with just a few minor spots of rust. but it also said some pinholes in the cab floors. i guess it depends on how much its worth to you. but i want to get me my own 76 f250 with a 390 because i grew up around these trucks. my friend has a 77 f250 blue and silver pickup that had a 351m. he paid 750 for it and the frame doesnt have a spec of rust. i claim its mine all the time because i did almost all the work to it and he always says its half mine. he had me put a 429cj in it that we pulled out of another one of his trucks. and he's only got 1500 in the truck and that includes buying it. so i bet you could find something cheaper and find a motor for it and you and a few friends could do alot of work to it.
heres the truck right here
edit: you could also think about all the parts you could possibly sell like the differentials, trans, transfer case, and body and frame. and keep the 460
Old Mar 28, 2009 | 07:15 PM
chris1450's Avatar
Personally I wouldn't take that truck. Ford didn't put the 460 in a half ton. The 3/4 ton truck has a leaf front suspention and the half ton has coils. I would look for a 3/4 ton for what your doing. It is a lot stronger. Bigger rear axle too. A 9 inch is a great axle.. for a car. I wouldn't pull around a big truck with a big block with it though. You can find a better deal I think.
Old Mar 28, 2009 | 07:20 PM
jimc2004's Avatar
the guys seems like he needs money. I think i could get it for 2500 or even 2000. Would you guys pay that for it?
You think DANA 60's are the minimum axle that should be with the 460?
Old Mar 28, 2009 | 09:04 PM
achap's Avatar
I had a 79 3/4 ton with the 460. Damn thing leaked so much oil...about a quart a day. Finally blew the engine.
Old Mar 28, 2009 | 09:23 PM
chris1450's Avatar
Yours was the exception then. They are VERY good motors. Far better than a BBC.
Old Mar 28, 2009 | 09:28 PM
ian51279's Avatar
Can't hurt to talk to him and see if he'd take less. Sounds like he wants it gone bad. And the 460 is just icing on the cake, doesn't matter if it came factory or not. The 9" axle is fine, they're used in drag racing all the time and it'll be just fine in that truck.
Old Mar 28, 2009 | 09:35 PM
achap's Avatar
yeah i loved the floor mounted horn button though
Old Mar 28, 2009 | 09:47 PM
ian51279's Avatar
Floor mounted horn button? That was a dimmer switch unless someone rewired yours.
Old Mar 28, 2009 | 10:32 PM
chris1450's Avatar
The ring and pinion in a 9 inch will hold up just fine. The axle tubes are the weak link in a heavy truck bouncing over burms. I wouldn't want it for that reason. I am not knocking the 9 inch.. just the aplication. The truck at the right price is fine.. and when the axle tube bends or breaks... upgrade. The front axle is no heavy duty unit either.
Old Mar 28, 2009 | 10:49 PM
The 460 was available as a factory option in the F-150 from 73 to 79, and I *think* from 87 to 91.
Old Mar 28, 2009 | 11:10 PM
FX41's Avatar
Originally Posted by Matts ford
76 f250 with a 390
That exactly what my dad has, I can't wait for it to be mine....frame up resto project for me.
Old Mar 28, 2009 | 11:15 PM
achap's Avatar
mine was horn! Just thought they came that way....bought it VERY VERY used for about a grand.
Old Mar 29, 2009 | 04:59 AM
Pickup Man's Avatar
You need to buy this truck. You need to remove the 3 inch body lift.
When the axles go, you need to replace them with 8 lug axles. Not sure if the 9 inch will break or not, but if that is a 44 in the front, it may have some issues with a 460 and big tires. Dana ftw.
Other than that, it looks like it is set up fairly nice, the body looks good, if there isn't a ton of rust on it, you need that truck.
Old Mar 29, 2009 | 05:14 AM
blackedoutV6's Avatar
looks to be a decent truck
if you can get him down to 2000 id jump on it
although thats probably one of the ugliest paint jobs ive ever seen lol
