Air filters
Old Oct 20, 2000 | 09:41 PM
Cowlady's Avatar
Question Air filters
I was hoping someone could & WOULD answer a question for me. If I switch to an Air raid or F&N filter, do I also have to change the exhaust? I know that if a motor breathes better it also needs to get the exhaust gases out more efficiently. Do these filters necesitate a change in the exhaust? Can I just switch the filter & leave the exhaust stock till I can afford a new system?
Any help will be appreciated. Thanks in advance.
If you can't beat 'em, you're NOT driving a FORD!
'97 F150 XLT ORP 4X4
4.6L/auto/power EVERYTHING,
nerf bars, 17" wheels, fog lights, trailer hitch w/electrical connector, front tow hooks, bed rail caps,
6 CD changer, lumbar support & 3 cow license plates - so far!
I'll fill in the rest as I get to know the truck better BUT it's big, it's pretty & best of all - IT'S A FORD! He's SO cute!
Old Oct 20, 2000 | 11:10 PM
DiXie Truck's Avatar
Talking
Hello from down South. You will not need to change your exhaust because you add a K&N Filter. Some Folks in here believe the K&N Filter lets in to many dust particles. I have one in my truck and never had any problems. The truck breaths much better with the K&N than with the stock air filter.
Old Oct 21, 2000 | 12:23 AM
DuckHntr's Avatar
Post
Hi Cowlady;
It's $50. vs. $200. for either the K&N filter or the Airaid FIPK. Personally I think the K&N filter inside the stock airbox is all you need unless you're looking for tenths of seconds off of 1/4 mile drag race times. $50. bucks for the K&N filter is money well spent. $200. bucks for the Airaid is ok if you can afford it...
Add the K&N filter and you'll notice an engine that 'picks up' a bit quicker than the stock paper element allows. Not a huge difference (in fact it's very minimal) between paper element and K&N but when you do your exhaust mod, you'll want at least the K&N filter.
Old Oct 21, 2000 | 03:59 PM
max mitchell's Avatar
Cool
The factory intake and exhaust is restrictive. The muffler only is a good improvement and so is the K&N filter only; if working with a budget. The biggest improvement I got for the money was removing the 2" air cleaner to filter extension, and replacing it with 3" (total cost $5). I was waiting on the 2000 CARB certification from K&N. Good Luck !
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back,
3" exit Y-pipe, Hellwig rear anti-sway bar,
Rancho RS9000s.
