Cooler
Old Mar 9, 2009 | 02:11 PM
stx2006's Avatar
Cooler
Does anyone know what I could use to seal a cooler and it wont release any toxic's into the food or drinks?
Old Mar 9, 2009 | 03:55 PM
kansasflareside's Avatar
What do you want to seal on the cooler? The lid so when it is tilted it doesnt leak? Need more info....
Old Mar 9, 2009 | 03:58 PM
stx2006's Avatar
The inside of the cooler. Like the bottom or sides.
Old Mar 9, 2009 | 04:11 PM
If the inside of the cooler is leaking, you'd probly be best off buying a new one. But if you are set on repairing it, I think your best bet would be 100% silicone caulking. If I remember correctly, it's toxic when in fluid form, but non-toxic when cured. I may be wrong though...
Old Mar 9, 2009 | 04:13 PM
stx2006's Avatar
Well I'm making a cooler to fit in my center con on my truck. So that's why I can't buy one..
Unless you know of one that's small enought to fit in there and look OEM...
Old Mar 11, 2009 | 09:38 AM
chiefFX4's Avatar
go and get you some loc-tite silicon adhesive. it can be used to repair and build fish tanks.
Old Mar 11, 2009 | 10:10 AM
Tumba's Avatar
X2
I didn't know Loc-Tite made one, but I've seen a pet store owner repair his fish tanks with clear silicon
Old Mar 11, 2009 | 10:14 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
So, you are making a container to put in your center console that will hold ice and not leak?
I'll just mention there are collapsible cooler manufacturers out there that make all shapes and sizes.
They even make them that look like lunch bags.
I'm sure you could find one very close to your console demensions.
If it's a little too big, it easily compresses in any direction.
If it's a little too small, it won't rattle around.
Old Mar 11, 2009 | 10:32 AM
esf's Avatar
esf
I was going to suggest an aquarium glue since it will obviously hold up to water, however, it is meant to bond glass and not plastics. It may not hold up well. Silicone probably won't hold up well on plastics. I used some on a plastic grass seed spreader (used for rock salt) that had a crack in it. It peeled off in the first 5 minutes of using it and it had cured for weeks before being used.
Old Mar 11, 2009 | 10:33 AM
stx2006's Avatar
Either ice or ice packs. Prolly ice packs so there isn't all that water in it when it melts.
Old Mar 11, 2009 | 10:56 AM
Raoul's Avatar
25 Year Member
Here is a truck to go inside your truck.
http://www.arcticzone.com/products/a...uck-lunch-box/
