What is your modem speed?
Top 3 times on ADSL:
1854.5 / 227.3
6800 / 833.3
8160 / 1000
I did the above test at around 7:30 am Eastern... The following test was just done at around 2:30 pm Eastern.
323.8 / 39.7
These speeds, I believe, are a combination of things. Your speed to/from your isp, your isp's pipeline to the net, and the pipeline to the servers that the website is on. Net congestion will really slow things down.
The rates shown at connection with a dialup modem is just that. What you connected at. Line noise will slow down your connection automatically and you won't know it, other than a slowdown in how fast/slow sites load... You'll probably blame it on net congestion anyway. I have yet to see a connection rate indicator change after the first connect rate is displayed. However, unless you have a perfect phone line, the rate does change.
The higher than expected speeds are probably a burst rate which is not a good indicator of the actual line speed. My ADSL connection is rated at 768 Kbps according to my phone company. My ISP says it's like having 1/2 a T1.
[This message has been edited by Dennis (edited 09-29-1999).]
1854.5 / 227.3
6800 / 833.3
8160 / 1000
323.8 / 39.7
Hmmm my 56k connection gets 38.9kbs/4.8k bytes sec at work.
Same ISP and username.
Almost forgot shows 46666 on the lights.
[This message has been edited by 54regcab (edited 09-29-1999).]
I got 43.2 Kbps and 5.3K bytes/sec.
97 F-150 S/C 4x4 ORP XLT 4.6 tow package
K&N , Flowmaster cat-back w/3" chrome tips. Bosch+4 plugs, Superchip.
Patriot fiberglass toneau cover, Westin chrome step bars.
Future mods: underdrive pulleys,4" lift, 16.5 wheels with 33's,ram air hood,and someday a supercharger.
157.3 Kbps
19.3 K bytes/sec
99 F150 XLT Silver 2WD S/C 4.2 5-speed, Superchip, Flowmaster muffler // Rear door switch guards - check them out at http://www.geocities.com/motorcity/show/5031
19.3 K bytes/sec
I sent this info to a friend of mine who has a "cable modem" and his results were around 770. I gots to get me one a dem !
Take care,
-Chris
'95 Eddie Bauer F-150 SC & '64 Falcon/Ranchero
Are you A.S.E. Certified ? If so, ask me about
iATN...the best tool you'll ever have ! ! And it's
free
Take care,
-Chris
free
This whole topic got me thinking, so have been doing a bit of reading.
Turns out the incredible speeds I've been getting is probably due to two things. The cache on my machine and the proxy server my ISP uses.
Whatever the speed is, I've downloaded IE5.0 in minutes instead of hours, so I'm happy.
Mine comes up 42.5kbps and 5.2k bytes/sec
Little computers tell me 36000 bps
1999 F150 Lariat
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield, VentVisors, Class III hitch, Ford molded mud guards, soft tonneau, factory CD with changer (thanks Dusty), tinted windows
Menasha, WI
http://www.fortunecity.com/silversto...ton54home.html
1999 F150 Lariat
5.4L 3.55ls
Menasha, WI
Tested 5 times at 10:50 P.M.
Highest was 741.8 Kbps / 90.9 K bytes/sec
'98 Bright Red XLT F-150, Regular Cab, Flareside, STX, 4.2L V6, Auto, 3.55, SuperChip, K&N High-Flow Air Filter, Mobil 1 motor oil, Westin chrome step bars, Magnum bug shield, Extang BlackMax.
