Reloading question
Reloading question
So, I grabbed a box of magnum small pistol primers instead of the standard small pistol primers. Reloading stuff you can't take back. Will I do any harm in using the mag primers??
It's going to depend on the cartridge and the powder load. If you are at max with a 9mm, it may push it into the "not so safe load". If it's a larger case and you are not at max loads, it shouldn't matter as far as pressure goes but it may effect accuracy and POI. Mag primers burn hotter and longer. It's called brisance.
Do not use them!!
A very bad idea as the pressure is a good bit greater with magnum primers as to the standard primers.
There is a reason there are magnum primers and standard primer.
digging this one out from a few days back....
Personally, I have used magnum primers in rifle applications that suggest standard primers. According to the research I've done, the magnum primers add about 1/2 a grain of powder charge. So just be sure to cut back your powder the middle or low part of the allowed range. Several VERY experienced reloaders actually recommend using magnum over standard in all applications when you may be shooting in extreme cold and/or wet situations.
I've decided that since my father in law also reloads, and has a 357 Mag, I'm just going to give them to him. I'm not going to mess with cutting powder back by a bit, or mistakenly get primers mixed up. I'll stick with the recipe I already have.
For me, since I hunt in extreme cold and wet conditions, I follow the recommendation of using mag primers in all my rifle loads. I don't keep standard primers on hand so mixing them isn't a concern for me.
Just putting it out there that it can be done, and done safely. However, if you have the concern about mixing them up, or are not comfortable doing it then it sounds like you made a good choice.
