3Wheels or 2......4X4
Old Jan 29, 2000 | 11:11 PM
GSXR's Avatar
Cool 3Wheels or 2......4X4
Hi.. I have a 2000SC 4X4, 3.55 regular axle, and i'm wondering when i shift it in to 4Wheel is the front LS, or is it same as the rear just one wheel peel. I'm wondering this because it seems to have alot more traction, than really i should have. ETC.(3 Wheels instead of 2)? Thanks in advance
Old Jan 29, 2000 | 11:44 PM
Pastmaster's Avatar
Post
I'm not sure Ford even offers LS on the front anymore. They used to, especially in HD trucks.
Old Jan 30, 2000 | 10:47 AM
fast46triton's Avatar
Post
Hint: 4 wheel drive
I believe its 4 wheels turnings.
Old Jan 30, 2000 | 07:06 PM
GSXR's Avatar
Lightbulb
fast46triton
I believe thats true if it has limited slip, but mine does not. Its regular axle.
Old Jan 30, 2000 | 07:19 PM
Post
The Limited slip refers to when you have it in 2 wheel drive, you have 1 wheel spining.
But I believe when you put it in 4 wheel drive, all wheels are turning.
Old Jan 30, 2000 | 10:09 PM
Firezap's Avatar
Cool
If you have LS (3.55LS) then it's just the rear. When in 4 wheel with a LS in rear you have 3 wheel. But from what it sounds like (1 wheel peel) you didn't get the 3.55LS rear axle. The added traction comes from the weight of the engine. Not sure about ford IFS but most front axles can house an aftermarket LS. What I've seen done is install a true locker in the rear and a LS in the front.
GOLD RUSH
'99 F150 XLT SC SB 5.4x2 Harvest Gold
3.55 limited slip/ trailer towing package/slip on extender mirrors/powerstop brake controller/Covermaster 1000 topper with wing/
BugflectorII/Ventvisors (front&rear)/3 www.f150online.com decals
http://members.xoom.com/firezap/truckpage.htm
[This message has been edited by Firezap (edited 01-30-2000).]
Old Jan 31, 2000 | 09:31 PM
Pastmaster's Avatar
Post
I wouldn't advise one though...Unless you are a serious guru...
-the cause excess tire wear
-and they also are Very hard to steer.
Old Feb 1, 2000 | 10:39 AM
JMC's Avatar
JMC
25 Year Member
Post
GSXR,
The front end of the F-150 is an open differential. The weight of the engine aids with the traction. The way a differential works is simple. Say the differential case speed is 100% and the left wheel is is turning at 90% of the case speed then the right wheel must turn at 110% of the case speed. So as long as surface traction allows it both front ( same applies to rear) wheels will turn. When one wheel locks (gets stuck) it turns 0% of the differential case speed so the other wheel spins 200%. Hope ths helps.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
SmittyBilt Nerfs, Borla Cat Back
Modified Air Cleaner Outlet Tube,
Superchips
Old Feb 1, 2000 | 01:54 PM
Henry Ellal's Avatar
Post
LS rear is two wheel and locking in the front gives you 3 wheel. Ford don't offer true 4 wheel drive. Come to think of it, I don't believe anyone offers true 4wd, at least not since International.
Henry.
99 F-150 XL 4x4. RC Flareside 4.6 5spd, 3.55LS. gibson 3" cat-back, K&N Gen ll.Westin step bars.Ventshade window deflectors and bug deflector. rhino liner and a cool white shifter ball.
Old Feb 3, 2000 | 12:58 AM
GSXR's Avatar
Post
Thanks everyone starting to understand.
