Morning Sickness-Int.Lamps and El.Windows
Old Aug 21, 1999 | 02:07 PM
EP's Avatar
EP
Unhappy Morning Sickness-Int.Lamps and El.Windows
Several mornings and once in the evening, I have started my engine and the windows plus the interior lamps will not work for several minutes. All other stuff works fine. Dealer looks at it and can't duplicate the problem. The tech. thinks the battery saver relay is to blame but can't get the engineers at Ford to buy into his theory of low current/low resistance through the relay could be causing oxidization on the contacts. Too far into the think tank for me, but I do believe in that target area. The tech,off the record, suggested that I switch the int. lamp relay with the battery saver relay when it occurs again... Is it possible that a fuse could be in a condition that the heat from the current causes expansion thus completing the circuit? There is a fuse that affects those relays, but I would expect the radio and other accessories to have similar problems.
'99F-150 4.2L 6cy auto stock radio cass
Old Aug 21, 1999 | 09:19 PM
JA_Stang86's Avatar
Cool
I would have to guess no. If you have a blown fuse there is no current to warm it up and make contact. Possibilty of a ground problem. Nothing works, drive a while and it vibrates enough to make good contact, they work. If you have a schematic, look for something in common with all effected systems. Start there. Good Luck.
Jeff
1999 F150 Lariat
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield, VentVisors, Class III hitch, Ford molded mud guards, soft tonneau, factory CD with changer (thanks Dusty), tinted windows
