Excel Gurus
Old Aug 19, 2008 | 12:35 AM
crashtheline's Avatar
Excel Gurus
Alright so basically what i have is a three sheet workbook.
Sheet 1 = Delivery report with item numbers.
Sheet 2 = 800 different item numbers, each on their own line
Sheet 3 = what i need done will go here.
Basically what i want excel to do is check my delivery report for all 800 different items and put the matches in Sheet 3.
I want to have sheet 3 show me the items that are coming in that match my list in sheet 2.
Does anyone know a formula or function that would work!?
Old Aug 19, 2008 | 07:28 AM
kingfish51's Avatar
I don't have all the steps, but I believe what you want to use is VLOOKUP.
Old Aug 19, 2008 | 10:19 AM
darrinp10's Avatar
Not quite sure I understand what you are trying to do. But I think the VLOOKUP should work.
If that doesn't work, you might mess around with the IF THEN function, that can get pretty involved though.
Old Aug 19, 2008 | 10:27 AM
Roush8702's Avatar
how is your data getting into sheet 1, do you have a sample you can send.
Old Aug 19, 2008 | 12:08 PM
WarEagle1982's Avatar
Vlookup is the answer I believe.
Old Aug 19, 2008 | 01:06 PM
Thanks Guys
Vlookup is exactly what i needed. I figured it out last night at 1:00AM haha.
Now what i need is a way to sort all the data on a final sheet.
The reason being i have 800 skus to check. So it may find one at A1 or it may find one at A800 and anywhere in between. Instead of scrolling through i need a way to LIST only the valid cells.
I tried a pivot table but its hard to format and won't refresh. I used a Visual Basic script to do a refresh but it only works sometimes and I think my corporate network blocks Scripting.
Any help again!? you guys are pretty good
Old Aug 19, 2008 | 01:30 PM
dkstone05's Avatar
Would adding a filter do the job? You can search within the filter.
Old Aug 19, 2008 | 01:31 PM
bangingd's Avatar
Record a macro for the refresh. If you cannot run macros you might be able to enable under security settings.
Old Aug 19, 2008 | 01:34 PM
Just looking into the filters now. Recording a macro would most likely have the same restrictions on the network.
Old Aug 19, 2008 | 01:53 PM
Filter is working. But It does not auto refresh lol
Old Aug 20, 2008 | 05:54 PM
You can make a pivot table auto refresh by click on the red ! point. It will then refresh your pivot table base on the new data.
I believe this is what you're after anyways.
