HAM Tower
Old Jul 24, 2008 | 01:48 AM
Shinesintx's Avatar
Originally Posted by Zaairman
Your neighbors are going to hate you, and unless you have some sort of wire/cable to tie the pole into the ground and add stability, you're going to get a lesson in wind resistance, followed by stress breaking points, then gravity.
It flowed so nicely
Old Jul 24, 2008 | 02:23 AM
styxnpicks's Avatar
our neighbor had a HAM tower in their backyard for YEARS. that thing was ugly
Old Jul 24, 2008 | 05:52 AM
risupercrewman's Avatar
I'm counting on you when DoomsDay comes, & you are out only hope for communication between the F-150 online human race & the attacking Aliens!..................
Old Jul 26, 2008 | 05:00 PM
My antennas are coming in on Monday, however, the weather doesn't look too favorable in my area... which really ticks me off... as usual.
I drove a 8' NEC approved copper grounding rod into the ground, and then attached 4 gauge wire to the ground rod using a copper grounding coupler. I then ran the copper ground, and I've got it wound up on the roof waiting to be connected to the mast.
I had a guy come over to check it out, and it looks to be fine as far as grounding and wind resistance.
The mast is so strong I can lean my ladder against it, and climb up... it's a little wobbly, but it's STRONG. I was guessing I was putting at least 100 pounds against it or more at the very top, telling me that my antenna would rip off well before the mast structure would. In which it would probably take 150+ mph winds... something that we don't get around here...
I'll post pictures when it's all done, which should be Tuesday if all goes as planned.
Old Jul 29, 2008 | 01:40 AM
Well, surprisingly I got my antennas up, and everything is functional... except I am having a problem when I transmit on HF, my touch lamps keep cycling on and off, and my fire alarm goes off.
I think I need to move my antenna.
I decided to cut down on the antenna, and decided to order a Diamond X-300A and a G5RV. The X-300A is working like a charm, and I can pick up stations as far away as 300 miles using simplex.
The HF antenna works excellent, except for the fire alarm and touch lamp issue. I think I will need to relocate that antenna further back... which is not a problem because I don't use it enough to require it to be in place all the time.
However I built my mast merely for the 144/440 mhz band.
Pictures will be up tomorrow, I promise!
Old Jul 29, 2008 | 02:07 AM
Impact9's Avatar
Shoot I think I'm the only one dying to see the photos. For $100 I damn well will follow your design and move my radio indoors.
Old Jul 29, 2008 | 03:56 AM
NoLongerJeepin's Avatar
Manual... You wonder why you can't find a woman...
What a great pick up line:
"Hey baby wanna go back to my place and take a gander at my ham tower?!"
Followed by mace to the face.
Old Jul 29, 2008 | 09:05 AM
dirt bike dave's Avatar
