ODBII Error Code?
Old Jun 20, 2008 | 06:26 PM
ThumperMX113's Avatar
ODBII Error Code?
The girlfriend just got home and her car is throwing a CEL. Can anyone tell me what this code means ...
P0456: EVAP CTRL SYS SMALL LEAK
Thanks guys ...
Old Jun 20, 2008 | 06:41 PM
Ranger7489's Avatar
fuel evap line, Did she drive over anything? They rest near the frame rails usually on other side of the fuel filter. I wouldent drive with a leak, Any small spark could...well you probably already know..
Old Jun 20, 2008 | 06:47 PM
Tighten the gas cap.
Old Jun 20, 2008 | 07:18 PM
Nope. I'm hoping it's not the same old problem. The V6 S197s had a problem with the fuel pumps that would throw this code. However she already had this problem and had it fixed. I just hope it's not back ...
Yeah, I did that. I cleared the code as well. So hopefully it'll be good to go. She says she thinks it was a "little" loose. Hopefully that's it ... I don't need to deal with anymore crap right now ...
Old Jun 20, 2008 | 07:19 PM
AlfredB18's Avatar
If it's not a loose gas cap, she best take it to a shop.
If you've never seen a diagnostic flowchart for an EVAP code, there's a reason a leak test (smoke machine) is used for that stuff.
Old Jun 20, 2008 | 08:05 PM
Quintin's Avatar
Gas caps usually cause gross evap leaks. Taking a wild swag, I'd say the canister vent valve is stuck/leaking.
Old Jun 20, 2008 | 08:58 PM
Shinesintx's Avatar
P0456 Its code for "should have kept your truck"
Old Jun 20, 2008 | 09:49 PM
Errr try again. It's not my car.
Old Jun 20, 2008 | 09:58 PM
JBMX928's Avatar
Graphics Contributor
Old Jun 20, 2008 | 10:05 PM
Speedy8's Avatar
Its code for "the mustang near me is 1001092918 times nicer!"
