How to? ring bell onto brick wall??
Old Apr 30, 2008 | 06:42 PM
YOMAN's Avatar
We moved into APT complex.
I have ring bell (special stuff for hearing loss alert) but HOW can I stick it onto brick wall without fall off the brick wall ? (is that clear eh , Alsupercab? )
Thanks!
YOMAN!
Old Apr 30, 2008 | 06:44 PM
alsupercab's Avatar
Old Apr 30, 2008 | 06:49 PM
YOMAN's Avatar
oh you havent meet any deaf or hard of hearing person? if no then thats why you have no idea what i m about..
Is there some stronger stick or glue can stick it onto brick wall next to door frame?
YOMAN!
Old Apr 30, 2008 | 07:07 PM
built54's Avatar
I dont understand a single word you just said
Old Apr 30, 2008 | 07:08 PM
JBMX928's Avatar
Graphics Contributor
gorilla glue, but to be honest thats not the strongest glue ive ever used... maybe im using it wrong .
Old Apr 30, 2008 | 07:12 PM
alsupercab's Avatar
liquid nails?
or is there a way to attach it using screws? You could always put in some hollow wall anchors (the plastic things made for brick) in the brick and use a screw if that is possible
Old Apr 30, 2008 | 07:32 PM
ThumperMX113's Avatar
Is it wireless? Otherwise aren't you going to have to wire it behind the brick? Does it have a spot for screws? If so just drill the brick, insert an anchor, and screw the bell to the brick.
Old Apr 30, 2008 | 08:17 PM
Craz3d he's deaf. I'm not really sure but I guess that affects his typing too?
Old Apr 30, 2008 | 10:13 PM
Ftruck05's Avatar
If he's deaf WTF good is a ringbell gonna do?? Kinda like braile on a drive-up ATM..... Anyways, it would be better to use an adhesive rather than drill holes. Try out some gorilla glue that should do it or as Craz3d said, epoxy. there are many 2 part epoxies made for brick and metal.
Old Apr 30, 2008 | 10:26 PM
lrhogfan's Avatar
I'll second the vote for liquid nails. It will adhere faster and probably better than gorilla glue with less expansion. I used some to adhere some copper house numbers to the exterior of my home since I didn't want to bother drilling into the brick. Worked better than anything else that I tried.
Old Apr 30, 2008 | 10:31 PM
J-150's Avatar
Tapcon screws
Old May 1, 2008 | 12:06 AM
Zaairman's Avatar
Liquid Nails ain't got nothing on JB Weld.
Old May 1, 2008 | 12:20 AM
Larry227's Avatar
If it's an apartment I would imagine he might one day move out and want to take it with him. Anything permanent may not be a good option. Screws would be best.
Old May 1, 2008 | 12:21 AM
rsbeachbum2's Avatar
I still prefer 3M's 5200 better.
Old May 1, 2008 | 12:27 AM
nuclearthreat54's Avatar
When your deaf or hard of hearing, you are probably taught ASL(American sign language) and the grammar for that is completely different from English. Now, idk his situation but thats what makes the most sense. Hopefully he'll be able to clear that up.
