Old Dec 30, 2011 | 12:58 PM
  #71311
What is VVT and VVL?
Old Dec 30, 2011 | 01:03 PM
  #71312
Ok, I googled. I have no idea how they accomplish that, or why it helps.
Old Dec 30, 2011 | 01:30 PM
  #71313
Yes Google is amazing.....
Old Dec 30, 2011 | 01:32 PM
  #71314
I just learned that!
Old Dec 30, 2011 | 02:13 PM
  #71315
Variable Valve Timing, Variable Valve Lift
VVT think of spark advance on steroids, its changing when the valves open (early more power) (later better fuel economy)In relation to the stroke of the piston. You can squeeze more power on acceleration, and "detune" the engine during coasting/braking for more economy
the 3v 5.4 have VVT (cam phasers)
VVL is the best of both worlds as well, you can have a nice low lift cam at idle that produces smooth nice idle that "momma" likes, and then switch to highlifting cam that produces the higher power numbers that "daddy" likes. With the same camshaft installed
Old Dec 30, 2011 | 02:19 PM
  #71316
Interesting, except Momma likes a good lopey cam in my case.
Old Dec 30, 2011 | 02:20 PM
  #71317
Although I normally prefer the silver and black HDs, this one is certainly an eyecatcher.
https://www.f150online.com/forums/tr...dson-sale.html
Old Dec 30, 2011 | 02:24 PM
  #71318
Just saw that, i dont know that i need another salvaged title truck tho
Old Dec 30, 2011 | 02:30 PM
  #71319
SETCHAN's Avatar
Build Tracking Moderator
When coasting, like when you turn into a driveway, the truck slams into 1st gear, or if you just barely get moving and have to let off, it slams into second. Just discovered there is TSB 11-10-15, a reflash to fix that. I will take it in next week.
HARSH 1-2 SHIFT BELOW 24 KM/H (15 MPH), HARSH DOWNSHIFT SHIFTS - FLARE ON UPSHIFTS - BUILT ON OR BEFORE 4/15/2011
ISSUE:
Some 2011 F-150 vehicles built on or before 4/15/2011 may exhibit a harsh 1-2 shift at or below 24 Km/h (15 MPH), harsh downshifts and/or a flare on upshifts.
ACTION:
Follow the Service Procedure steps to correct the concern.
SERVICE PROCEDURE
Reprogram the Powertrain Control Module (PCM) using IDS release 75.03 and higher. This new calibration is not included in the VCM 2011.9 DVD. Calibration files may also be obtained at www.motorcraft.com.
Using the IDS tool, clear the transmission adaptive table - Select Tool Box, Powertrain, Transmission, clear Transmission Adaptives.
Perform adaptive drive procedure. Refer to Workshop Manual, Section 307-01 Diagnosis and Testing, Road Test - Adaptive Drive Cycle.
NOTE: PLEASE ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE'S COMPUTER TO LEARN THE TRANSMISSION'S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS.
Old Dec 30, 2011 | 02:34 PM
  #71320
ISSUE:
ACTION:
SERVICE PROCEDURE
Yes, thanks. I saw that yesterday. My truck was built Dec, 2010 and has the harsh shifts.
Old Dec 30, 2011 | 03:08 PM
  #71321
Taking off early. Going to go wash the truck, then run to Brownsboro, pick up Momma and Maggie and head to Burleson. Bye ya'll.
Old Dec 30, 2011 | 03:12 PM
  #71322
ian51279's Avatar
Be safe Jim.
Im headed to a friends in Houston for the night. Gonna do some fishing and stay on his boat.
Old Dec 30, 2011 | 03:14 PM
  #71323
Really late linch for me
Old Dec 30, 2011 | 04:46 PM
  #71324
shifty219's Avatar
Off to work soon for me
Old Dec 30, 2011 | 04:50 PM
  #71325
shifty219's Avatar
I don't think I could switch back and forth.
Ive worked 12's for so long ( 2 day 2 nights) that I dont think I could work 8 hour shifts again.
