Old Apr 13, 2010 | 02:33 PM
  #42091
Originally Posted by f150fella08
been a month and a half....whatd i miss?!?!
Nothing, John hasn't talked to the girl yet.
Old Apr 13, 2010 | 02:39 PM
  #42092
f150fella08's Avatar
stupid john
Old Apr 13, 2010 | 03:08 PM
  #42093
here ya go dave (ford 10.5")
To maintain driveline balance, index-mark the driveshaft flange yoke and the pinion flange.
Remove the 4 bolts.
CAUTION: The driveshaft flange yoke fits tightly on the pinion flange yoke. Never hammer on the driveshaft or any of its components to disconnect the yoke from the flange. Pry only in the area shown, with a suitable tool, to disconnect the yoke from the flange. Using a suitable tool as shown, disconnect the driveshaft flange yoke from the pinion flange and support the driveshaft using mechanic's wire.
CAUTION: Index-mark the pinion flange to the pinion shaft prior to removal. Use the special tool to prevent the flange from turning while removing the lock nut and washer.
Old Apr 13, 2010 | 03:11 PM
  #42094
Instructions for the D80 are slightly different
Old Apr 13, 2010 | 03:13 PM
  #42095
stupid john
I know, I must be awful with girls seeing how I don't have one
Old Apr 13, 2010 | 03:26 PM
  #42096
oh yea that, shes not the gym girl john!
Old Apr 13, 2010 | 03:48 PM
  #42097
Breaktime!
Old Apr 13, 2010 | 04:06 PM
  #42098
dsq3973's Avatar
Thanks Patrick that helps alot I know what I am doing on Sunday.
Old Apr 13, 2010 | 04:09 PM
  #42099
I know... she's way better
Got back from a run... time to get ready for work. Talk to ya'll tonight
Old Apr 13, 2010 | 04:40 PM
  #42100
i just saw the video "the call" by matt kennon..pretty good
Old Apr 13, 2010 | 04:46 PM
  #42101
its nice having alldata at work
Old Apr 13, 2010 | 04:52 PM
  #42102
dsq3973's Avatar
I can imagine. Do you happen to know what the torque specs are for the everything when I reassemble because if I remember right there is a crush sleeve in there that I have to replace as well?
Old Apr 13, 2010 | 05:33 PM
  #42103
NOTE: The pinion flange must never be hammered on or installed with power tools. Using the special tool, install the pinion flange.
Use a suitable tool to prevent the pinion flange from turning while installing the old washer and the pinion nut.
Tighten to 637 Nm (470 ft. lbs.) .
Using a Nm (inch lbs.) torque wrench, rotate the pinion. The rotational torque must read 2.9 - 5.0 Nm (25 - 45 inch lbs.) .
To increase the drive pinion bearing preload, remove drive pinion bearing preload shims. To decrease the drive pinion bearing preload, add drive pinion bearing shims.
While using a suitable tool to prevent the pinion flange from turning, remove the old washer and pinion nut
Using the special tool, remove the pinion flange.
CAUTION: If the drive pinion Seal becomes ****ed during installation, remove and install a new one. Make sure the garter spring remains in place during assembly. If the spring is dislodged, a new drive pinion seal must be installed. Using the special tool, drive the pinion seal into the housing.
Coat the pinion seal (rubber lips) with axle lubricant.
Using a Nm (inch lbs.) torque wrench, rotate the pinion. The rotational torque must read 0.6 Nm (5 inch lbs.) higher with the new pinion Seal installed
Old Apr 13, 2010 | 06:04 PM
  #42104
dsq3973's Avatar
Patrick, thank you very much for the information I owe you a case of your favorite beer.
Old Apr 13, 2010 | 07:00 PM
  #42105
06F150STX's Avatar
Howdy gang!!!
Pat, you are the man. The info you gave me about my wife's blend door was easy. I just hope Dave can follow instructions.
