raptor 660 engine problems
Old Apr 17, 2008 | 08:38 AM
built54's Avatar
My friend has an 01 raptor, 700 big bore kit, big carb, race cams, all decked out. well he was racing it, and it lifted the cylinder, pulled the bolts out. would this be possible to heli coil? or should I Let a machine shop do it? I can buy it from him right now for $2200, its in great shape.
Old Apr 17, 2008 | 10:10 AM
CRF250rider1000's Avatar
Wow! it lifted the rods out of the case your saying???
Old Apr 17, 2008 | 01:19 PM
doitonall4s's Avatar
id say let a machine shop deal with it or buy a new engine....something went wrong if that happened
Old Apr 17, 2008 | 02:27 PM
Duneracer's Avatar
Raptor
Post the question in the Raptor Forum on this website:
http://www.bluetraxx.com/
I have a Raptor 660 and they have been great help to me over there.
Old Apr 17, 2008 | 06:00 PM
budsstuff's Avatar
make sure the trannys been redone on it. the 01's were prone to having them go out. but if its built like you say its prob already been done.
Old Apr 17, 2008 | 11:18 PM
built54's Avatar
Yea the bolts pulled out of the case...
Old Apr 18, 2008 | 01:28 PM
time to buy a Honda
Old Apr 18, 2008 | 07:18 PM
built54's Avatar
Originally Posted by doitonall4s
time to buy a Honda
yeah that helps
Old Apr 18, 2008 | 07:38 PM
BlacknGold's Avatar
Registered User
I dont personaly like the raptors, usualy called craptors. they have alot of internal plastic gears. I like my LTR.
Old Apr 18, 2008 | 08:37 PM
Get a machine shop to do it. Hopefully they will be able to. If not you may be looking at some new cases
Old Apr 19, 2008 | 12:27 PM
built54's Avatar
Yea I can get a new case for under $600... just an option
Old Apr 19, 2008 | 04:28 PM
As long as your comfortable diving into engines and have a press, impact wrench or pullers, and assembly lube you will be good to go
Only problem is if it happened once, it is bound to happen again
Old Apr 19, 2008 | 04:51 PM
built54's Avatar
yea Im not scared to do anything with engines, obviously lol look at my truck, but ill give it a shot
Old Apr 19, 2008 | 06:17 PM
BlacknGold's Avatar
Registered User
If you do so decide to by the raptor, you have to get a special yamaha rtv sealer for when you put the two cases back together. The is no gasket due to the tight tolerances(sp).
Old Apr 19, 2008 | 07:03 PM
scottbigred's Avatar
i wouldnt helicoil it. get a machine shop to open the holes up and rethread them and put stronger bolts in. but if it happened once, more than likely will happen again. idk id buy a predator lol.
