ARE Cap summer storage
Old Apr 8, 2008 | 03:42 PM
a1aprt's Avatar
I have an '03 SCrew that has an ARE cap on it that I use for the winter. Now that it is summer, I need a place to store this. Does anyone have any ideas on what I can use to store in my garage? Looking for something that I can take off and on by myself. Thanks
Old Apr 8, 2008 | 04:25 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
What a fun project that would be to design.
Envisioning my garage, I'd be backing my truck in, and say the bottom of the cap is 5 feet from the ceiling.
Two pieces of chain 4.5 long bolted to the ceiling about 8 feet apart at the back of the truck, eyebolt a 2x4 across.
For the front, the garage door would be in the way in the open position so, I'd build a couple of 'hall trees' with sturdy legs that another 2x4 could be placed securely.
I'd back the truck in until the board on the chains started to swing back.
Then I'd climb in back, unclamp the shell and lift the back up until the board swung inside with me.
Then I'd lift the front and block it and climb out and slide the front 2x4 in place, remove the blocks and the top would be suspended from the ceiling in the back and the 'tees' in the front.
I wouldn't lose that spot in my garage because the truck could still use it.
I could also mount and unmount the top by myself at my whim.
Of course if your garage is big enough that the shell isn't under the door when it's open you could just use four chains off the ceiling.
The whole rig should set you back about $30, unless you have a bunch of chain and wood laying around, like me.
It's a good thing for you I stayed at a Holiday Inn Express last night.
Old Apr 10, 2008 | 02:18 PM
Raoul's Avatar
25 Year Member
I was looking at the space my garage door took up when open.
If my truck was backed in a cap would clear it easily.
Meaning there would be nothing above the cap except ceiling, no door in the way.
The material list would be:
Four open eyebolt screws.
Four open eyebolt w/nuts.
Four pieces of chain cut to length.
Two 2x4s
If I ever get a cap I'll probably do this.
I had a cap on my last truck and had to always get neighbors to help with the on and off.
Old Apr 10, 2008 | 02:57 PM
gixxerjasen's Avatar
You could do something similar but run a single industrial strength cable and run something out to the corners. Then a pully system to lift it off the truck with some guide wires attached to keep it from spinning while it's sitting on the ceiling till fall. I've seen something similar done with dirtbikes.
Old Apr 10, 2008 | 03:00 PM
harleyrider's Avatar
Not sure about your ARE cap, but my old one fit over the bed rails, not sit on top. That always created a problem when storing becuase I didn't want the weight of the cap being supported by the side lips. Couldn't use the Raoul plan as the rear was a glass, so no support there and the sides aren't designed to hold the weight. I ended up using some 4x4 post and building a frame that was as wide as my bedsides the fit into my old boat. We just slide the ARE off the bedrails onto the frame that was on my boat. Boat is kept under a metal carport in the backyard.
Old Apr 10, 2008 | 03:02 PM
Well, You could construct some tall, wide saw horses. Wider than the truck and taller than the bed. Slide them under the cap and still be able to back under it.
Old Apr 10, 2008 | 04:27 PM
Raoul's Avatar
25 Year Member
I figured the 'chains bolted to wood' from the ceiling wouldn't work for everybody.
Ok, so keep the four chains and then, stay with me now,.....giant suction cups.
Old Apr 10, 2008 | 04:30 PM
You're really into the chains aren't you?
