Removing burnout marks
Old Jan 25, 2008 | 12:41 AM
I know it sounds a bit on the comical side... but it's really not..
This past summer I cleaned out my truck and everything to go wash it, and I spun my tires a little bit in the middle of the driveway and it left a mark. Also, when getting my Dakota on the tire ramps, I peeled a little rubber in the garage.
How do I get these stupid marks out?
I know the one in the driveway was my fault for screwing around... but I want to remove the ones out in the shop.
I've tried power washing them, scrubbing them, etc... nothing seems to work. I can't figure it out.
Old Jan 25, 2008 | 01:14 AM
Bartak1's Avatar
If I spun a tire with that lil 6 banger I would be puting a glass case around it and taking pic, not trying to get rid of it ! SAVOR THE SMALL EVIDENCE OF POWER!
But..concrete floors???
Old Jan 25, 2008 | 01:39 AM
Bleach.
Old Jan 25, 2008 | 01:49 AM
azmidget91's Avatar
i was gonna say power washer but you already tried, its always worked for me
Old Jan 25, 2008 | 06:51 AM
Ftruck05's Avatar
Muratic acid diluted 1:1 with water. If that dont work bust out the grinder and wire wheel.
Old Jan 25, 2008 | 08:50 AM
serotta's Avatar
RP is the resident expert on removing tire marks from a concrete driveway.
Old Jan 25, 2008 | 10:28 AM
1fast4.6's Avatar
Jackhammer!
Old Jan 25, 2008 | 11:18 AM
gixxerjasen's Avatar
Originally Posted by Bartak1
SAVOR THE EVIDENCE OF SMALL POWER!
Fixed
Old Jan 25, 2008 | 11:31 AM
Zaairman's Avatar
Give it time. They will fade.
Old Jan 25, 2008 | 01:04 PM
06darkstone's Avatar
just cover them up with new ones!
Old Jan 25, 2008 | 01:10 PM
ktexas's Avatar
You can probably go to your local pool supply house (maybe an SCP in your area?) and pick this up. I didn't know this worked?
Old Jan 25, 2008 | 02:41 PM
jk007's Avatar
This stuff is the bomb, it gets almost anything off of concrete. It should do the trick... I was going to recommend it but Ftruck05 beat me to it.
Old Jan 26, 2008 | 12:36 AM
Thanks guys... I'll try the Muratic acid trick.
Old Jan 26, 2008 | 08:53 AM
Ftruck05's Avatar
We use it to wash brick. Make sure to rinse the area off really good afterwards though.
Old Jan 26, 2008 | 11:07 AM
Camarothatcould's Avatar
lolz. . . half tap of t3h throttle one night. . .
We have a habit of taggin each others houses out where I live. Sometimes we back up into our buddies driveways and let em rip!!! I always win cause for some reason, both of my tires spin.
as far as cleaning them up. . . no fawking clue
