get your trucks build sheet
In case you dont't know this and I am sure its been posted before. I bought an used F-150 and was not sure of all of the options that were on it. Mainly I wanted to know the gear ratio and if it had the limited slip option. If you take your vin number (they use the last 8 digits) to yur ford part department, they can run it and print out the build sheet that shows all of the options for the vehicle. So now I know I have the 3:73's and the limited slip diff.
Sorry if this is a repeat.
L8R Nick
L8R Nick
This works too...gives some of the info...you can also find your gears by checking a sticker on your truck...I think in the door maybe it was.
https://www.fleet.ford.com/maintenan...ls/default.asp
seems about right to me.
